Excellent idea, I have the same issue, I'll be heading to the hardware store today. ThanksHere are some pictures of a door mod I'm trying out. I noticed my door frame edge on the top and bottom were at the very top of the door gasket so I cut some bushings to lift the door up so the door frame edge would be in the middle of the gasket instead of the very top. I wasn't experiencing any issues with leaking(that I know of) but still felt it could be better. If it works out I'll figure out a better solution for the bushings moving forward. The red in the gasket picture is highlighting where the door frame was hitting and where it hits now. You can see a faint chalk line on the gasket in the new location where I checked the contact points.
I was getting a slight smoke smell when I turned the air down which seems to be gone but I'm also pretty congested right now. I was thinking it was the pipe but maybe it was the door? Who knows! Maybe some others are having similar "issues" and this may help.
Just curious how that's possible, if they're made on the same assembly line. They must have jigs or something that's used to align the hinges before welding.
This confuzzles me.
I understand if one's 20 years old and another is brandy new, but several relatively new stoves with different door alignments seems weird.
Anyone know why the efficiency specs for the new Blaze King 30's [81/75] are so much lower than the basically same size Princess [88/81].
Does it have to do w lower emissions .......30's - 0.97......Princess - 2.42?
Thanks
Great question! When a manufacturer tests a wood stove (currently) we test
at four different burn rate categories. There is a spread for each of the
burn rate categories. For example you can hit the "sweet spot" in the low
burn and get a different result than you might at the upper end of the same
burn rate. These spreads in each of the burn rates can result in
significant differences in test results.
The EPA is reviewing the current standards and the test method itself. In
their review, there is the possibility of cordwood testing as an option.
The goal of course is to get real world emissions and efficiency values from
testing.
We can assure you that the future changes will have a significant impact on
both the emissions and efficiency numbers as they will be reported in the
future.
Regardless of which Blaze King you select, we assure you will receive the
best possible burn times with the greatest level of turn down rate in the
stove industry. Of course there are many new catalytic stoves coming to
market in the future.
Of course, only Blaze King has refined the experience and design of
catalytic wood stoves over the past 30 years. So much so that we now offer
a 10 year 100% warranty on the combustors in our catalytic models. Just
keep the door gasket tension nice and tight and you should receive a decade
or more of reliable clean and efficient burning.
Thank you for your question.
Chris
Just checked mine and it is nicely centered. But thanks for making us aware of the potential problem.Here are some pictures of a door mod I'm trying out. I noticed my door frame edge on the top and bottom were at the very top of the door gasket ...
Would any of you bk owners be kind enough to post a pic of the fire? We have narrowed our stove search to the bk scirocco or pe super 27. I know the pe has a nice flame but the only bk's we have seen are brand new at the dealers and not in use. Thank you.
The only time I see flames is when I'm burning mine after a reload for 30 minutes or so. If the stove is undersized for your space and you have to run it hot you may see more flames than I do. I get the occasional flame up and can watch flames if I want but choose to conserve me fuel.Would any of you bk owners be kind enough to post a pic of the fire? We have narrowed our stove search to the bk scirocco or pe super 27. I know the pe has a nice flame but the only bk's we have seen are brand new at the dealers and not in use. Thank you.
Thanks, I think I can live with the somewhere in between. We live in the north west with moderate climate. The stove looks to be built like a tank. It would be over sized for our well insulated house. Can you burn a low fire without activating the bypass?
WOW..mine has never been that black!Sometimes it looks like this
Sometimes like this
Usually somewhere in between.
Never burn without by-pass open unless just starting fire and not up to temp.Thanks, I think I can live with the somewhere in between. We live in the north west with moderate climate. The stove looks to be built like a tank. It would be over sized for our well insulated house. Can you burn a low fire without activating the bypass?
Had a 16 hour burn on huge ash splits last night,house maintained 75*with absolutely no temp deviation,could have gone longer but I'm leaving for the day,so I just threw in 3 hickory splits to hold until 6pm.Burned the stove on 2.5 for 3 hours before bed and had plenty of flame to watch.Since we have a bunch of new BK owners this year I figured I'd start a thread to discuss everything BK. This may help limit the amount of BK threads and give us one convenient place to ask questions or just boast about our burn times without ruffling any feathers.
Anyway I'm on my second season with the Princess and it continues to impress me. I getting ready to load after 25+ hours, the load was a pretty full load of scotch pine and elm that was standing dead for years.(some pieces punky) Our overnight temps were in the 30's and our daytime high was 41, we've had 30+ mph north winds all day. House is still a comfy 72 at this point.
Nice pic, I see the best seat in the house is gone!Here's my Princess burning at #2 with 8 splits of Oak. Nice lazy flame and clean glass. Once I dip below #2 the glass starts to darken up on the sides. I have found this setting works best for me most of the average Winter days and give me a good 12 hour burn with plenty of coals for reload. View attachment 95407
BTW, not to go too far off-topic, but do you (dear readers) find it useful that this thread shows the original post at the top of each page? It's an add-on I'm trying out.
