20 inch bar on a MS390?
smokinjay said:
+1 but start out full skip!
On a 390 - you might be right on the money with going skip chain right out of the chute.
oldspark said:
Any bar length 24 and over will benefit for a skip chain correct?
I don't agree with this. I consider a skip tooth chain to be an aid to a saw that doesn't have enough power to correctly pull a full chisel chain. Just my opinion.
There is no advantage to running a chain with less cutters, unless you don't have the power to pull it properly. A 390 with a 24" bar is gonna be on that edge. In this situation a skip tooth might be the little boost it needs to keep the RPM's up in the cut.
Depends on what powerhead the chain is strapped to. 24" bar on a 660 will make it cut slower.
You may be right but I thought the wood cleared out quicker and it had a benefit other than just running a bigger bar than the saw could handle, am thinking about getting a skip tooth for my 28 inch bar on the 045 to try it out, seems to pull it fine but was under the impression the skip tooth was better on a longer bar.
This is on target! 390 however just cut to the case out the shoot!
Jags said:
Kenster said:
Follow up on my original post....
1) Since I am running 3/8" now, I simply need to find a 24" bar and any 3/8 chain?
2) Since this will be only an occasionally used bar, would it be a sin to put an Oregon bar on my Stihl to save some money?
Yes.
No.
On the chain, I would start out with the full chisel. If you find that you bog in the cut, consider a skip tooth.
If we're talking possibility of dirt, semi-chisel may be better option, for keeping it sharp.
Nobody's yet mentioned gauge (thickness of drive links)- bar and chain must be nominally the same.
So as long as my 045 will pull it I am better off with the regular chain? Not trying to hyjack this thread just trying to add to the skip tooth vs regular chain.
Agreed - that is why my statement was pointed at the 390 with 24" bar.
And Sparky - I dunno when you get to the real big bars. Just not my game. On the less than 25" bars, I find skip tooth to only benefit saws that are trying to pull too much bar.
Yes. How many cc's you got?
75cc I already have the bar on the saw and it does pull it with a regular chain but will I see a benefit from the skip tooth?
My current chain is 3/8, .50, 60
You should be golden with anything up to a 28 inch. 32 go full skip. Skip good for dirty wood less teeth to sharpen.
You also need to consider the space between the cutters for chips. A long bar in big wood will cut a lot of chips and have to carry them a long distance.
41 inch on a non skip 880 is like pouring water out the back of the saw. Bigger the saw the bigger the chutes is.
smokinjay said:
If you really like the 16....I would go 24 inch and be able to do about anything that comes along.
I would agree. I have a husky 50cc with a 20" bar. It is underpowered, but gets the job done. 24" sounds about right on a 60cc saw.
I have a 390 and a 20" its all i have ever run. It can pull all the bar through oak. Keep a sharp chain and it will be fine, it can get bogged up if you force it though but the 390 is a big saw !
smokinjay said:
LLigetfa said:
Jags said:
I believe that this was Lee's way of typing out a sound track to a bogging, overbar'd saw. :coolsmirk:
No, I think that's the sound of a dull saw making fine dust and being rocked back and forth to try to get some bite.
I am a firm beleaver that if the log is 45 inchs a 20 inch bar is a knife at a gun fight kinda thing. Muff modded 390 will pull a 24 fine!
Hear! Hear!
Yes.
No.
Agreed, except skip the full comp chain and go right to a skip tooth.
I've run a MS390 (stock) with Stihl Full Chisel (33RSC72) on a 20" bar. It pulls that with authority. If you wanted to go 24".... I doubt it would have trouble with that and if going full-skip seems too extreme there's always Stihl's half-skip full chisel....
I'm not a fan of big bars and don't use them but this is extremely good advice if using a bigger bar than what is recomended by manufacturer.
FWIW, I like the skip chain on the 24" bar & longer, cuts faster than full comp chain by nearly a full second in a timed cut on 30" red oak. 064 revs @ 12,500 with an 8 pin rim I get pretty decent chain speed, & plenty of power in the cut. I tend to run the shortest bar I can get away with for the reason Lee mentioned. As someone already mentioned, less teeth to sharpen on the skip chain. A C
You got it.
You got it.
Yea thanks, hard won experience there, but lessons I'll never forget LOL. HAPPY NEW YEAR!!!!!
Stihl recommends 16"-25" bar on a 390.
Just sayin'
Just sayin'
Uhhhh,,,,, no!
http://www.stihlusa.com/chainsaws/MS391.html
