Would two 500 gallon propane tanks on end be suitable for a power failure dump zone if half the tank is higher than the Solo 60 boiler?
Since the Tarm is about 4' high and I could place the tanks so there is 4' of tank above the boiler top, could gravity be used to pull the cold water at the bottom of the tank into the boiler during a power failure?
Could this work as a pump-free way to charge the tank during normal operation?
Thanks for your advice!
