- Feb 5, 2006
- 400
Check out this insert: Enviro Kodiak 1700
http://enviro-fire.com/fireplace-products/wood/fireplace-insert.html
Based on all the dimensions the 1700 insert should fit the smaller heatilators (like mine e-39), and the most problematic measurement for me was the location of the flue cut out for the chimney pipe/liner.
I could find a fair amount of inserts that would fit, but getting one that would fit and have the flue pipe locations match up was tough. The heatilator has a flue center of 14 1/2 inches from front face of fireplace, and most inserts were about 9 or 10 from the front. No way to fit an offset adapter up there if your going as big as possible cause clearance is too small on the top.
This appears to be dead bones on with the heatilator. It has a 2.5 cu ft firebox, 74,000 btu's, 75% efficient. It also has the abitlity to attatch the take off collar from the inside of the insert for really tight installs (like mine).
Good luck and happy hunting
unit. The BTU's may also be a bit fudged, but most are.
