Been lurking, been thinking, ready to bite the bullet and I'm going to try to include all the information I can. With nothing ripped out yet, there is a fair amount of some assumptions.
The wife and I call this "the black hole". Black fireplace? Check. Black tile granite on the floor? Check. Black tile granite on the surround? Check. Black tile granite on the counter top in the kitchen? Not anymore!
Currently, the Majestic Sovereign 36" Woodburning Fireplace is installed. It's "nice". It's "cute". I would love for it and its surround to be replaced by something that can actually help heat the house (Two heat pumps that can get overwhelemed when it hits the mid 20s in the winter). So, not a whole house heater, just something to help the first floor that is very open (except for the bathroom) which about 1000 sq ft.
But to the limitations. The fireplace is zero clearance and the chimney is a bump out so three sides of it are outer walls. The sane person would suggest going with a ZC High Efficiency fireplace or hearth heater but the price for the heat provided, and not to mention the blower that would have to run...meh. Not that my mind is set but if what I'm hoping to accomplish is a lost cause, I'd rather listen to you all than a insert salesperson looking for a bigger commission.
I want to install a free standing wood stove where this fireplace is now located but again, limitations.
Depth: The Sovereign 36 requires 22.5" (haven't pulled it out yet so it's an assumption) and the hearth is 24". Overall depth to work with being 46.5 inches for: the stove, clearance, floor protection and shielding.The wife doesn't want the hearth to extend any further into the room but I figure I might be able to sweet talk at most another 4 inches out of her if it was make or break.
Width: The Sovereign 36 requires 41" and this is something I would love to expand, but it being a bump out chimney... not much wiggle room there. Measuring the outside of the bump out it's 51 inches so the actual rough open might be more than 41 inches but it's impossible to say at this point.
Height: The Sovereign 36 requires 44" and this is were there is some flexibility, to a point. I have no issues expanding up another 12" but of course... this is also exactly where the TV is mounted. Because life.
I am aware that it's an alcove installation. That I will need a HT chimney and a double walled stove pipe.
I'm trying to figure out what I can "get away with" in regards to the most heat but also "not burning down everything I know and love". So fully on board with all the heat shielding and venting (if that will reduce clearances) to make this happen. Unless it costs a million dollars at which point I'm out.
As an aside, the wife believes this to be a horrible idea and that I am "putting a hole in the house" which I'm just looking for others to commiserate with. I mean, there's already a hole in the house, I just want to make it more efficient! And she can make the surround as pretty as she wants!
TL; DR
Depth: 46.5" (The 16 inch clearance for the wood stove's door must be included in this measurement).
Height: 44" but can expand up to 56"
Width: 41" impossible to expand, may be wider, will know after demolition
Near as I can tell from the research I've done my options are:
Lopi Answer
Lopi 1750
Hearthstone Shelburne
But if I am missing another heating option I am open to anything. As well as providing more information.
![ZC fireplace to alcove free standing wood stove... hopefully ZC fireplace to alcove free standing wood stove... hopefully](https://www.hearth.com/talk/data/attachments/216/216214-1cf51c576aa7586186ed743170b8e71d.jpg)
TL; DR
Lopi Answer
Lopi 1750
![ZC fireplace to alcove free standing wood stove... hopefully ZC fireplace to alcove free standing wood stove... hopefully](https://www.hearth.com/talk/data/attachments/216/216213-00bf434c95f47a1c7386115e83810184.jpg)
