Hello all,
New user here and I've been looking over the threads to try and get as much information as I possible can.
In May, my wife and two daughters (ages 2 and 4) moved out of our townhome and into a single family a little more in the country of Maryland. It was a bank foreclosure that needed a face lift. We currently have 3.5 acres of property and about 2.75 of it is woods. Already had 3 oak trees drop in the woods this summer so wood is available. I've probably got 2+ cords already cut and stacked. Our house heats with oil and is approximately 2500 sq ft (two stories with a basement that wont be used much in the winter). Anyways, onto the fireplace.
The house has a zero clearance (majestic) and prefab chimney. The previous owners put in a gas insert. In order for the gas insert to fit in, they had to cut the ZC box. Also, they switched the chimney cap. The propane tank was taken by whoever leased it to the previous owners and I don't want a gas fireplace. period. So it has to come out and replaced
My #1 goal is heating efficiency/length of burn time. I'm nervous about what its going to cost me to heat the house with oil (even though oil is relatively inexpensive compared to what it has been in the past). My #2 goal is looks. This fireplace is in our main floor living room so am trying to make it look good. I am still keeping in the back of my mind resale value. My #3 goal is not spending a fortune. I'm still young and money doesn't grow on trees yet.
I had a local, large chimney/hearth company come out and look at everything (after I put a deposit down of almost $3,000). At first I wanted to install a wood burning insert. I went there mid summer and got the ball rolling. Took them a while to finally come out and tell me their final decision but I finally got it a few weeks ago. Was told wood burning insert wasn't an option b/c the ZC box has been tampered with too much and the insert was too hot for this. Does this seem legit given the pictures? Should I get a second opinion?
So onto plan B (which I have basically moved onto as well). They suggested a new high efficiency fireplace. The limited research I have done on these things makes me think they can put out some serious heat and could really help me on my heating bill. I was originally thinking a wood burning insert was going to cost me around $5,000 - $5,500 installed. After talking with the sales rep and him giving me the numbers for the Quadrafire 7100, replacement of ZC box pipe, labor, etc....he was thinking north of $7,500 at a minimum. This really made me wonder if all of this was even worth it.
After doing some research on here, I started thinking about a self standing stove in an alcove. Could I remove some of the lick and stick stone and set a self standing stove into it? My first concern was that my chase has 2 chimney pipes.....one for the oil furnace and another for my fireplace. Are they too close together for me to build out an alcove? Not 100% sure since this is a new idea I just realized I should consider. Side note, I think my wife would love this idea if done right. But nervous what this might cost
Then......my HVAC guy (who I have known my entire life and is a great guy, so I trust him) suggested a wood/oil furnace in the basement. My main concern here is can the existing piping handle a wood furnace? It's currently only handling an oil furnace which I know doesn't burn hot. Further.....if I spend around $7,000 to put one in....I still have an ugly ZC firebox upstairs that is cut up. Would probably need to spend some money here to fix it up.
So what would you suggest?
Questions:
- Any idea what kind of chimney pipe is currently in my pre fab chase? Class B - double wall? Will this need to be completely replaced if I go with a self standing stove or a high efficient ZC? Do I need Class A pipe for wood, period?
- Scratch the wood burning insert idea?
- Will the stonework need to be re done in order to fit a high efficient ZC fireplace?
- What would you estimate labor to be to install a high efficient ZC fireplace and new chimney pipe (in other words, how much do you think I need to tack onto the cost of my fireplace to get to a rough idea of what it will ultimately cost?)
- If I start thinking about the alcove......where do I start? Fireplace store or a general contactor? After looking at the pictures.....anyone have a rough cost on what it would be start to finish? $10k? Just trying to gauge if I want to even consider a project like this.
- Anyone have experience with wood/oil furnaces? Should I really consider this option for peak heating efficiency?
Thank you for any help you can provide! It is much appreciated.
Bryce
Questions:
Bryce
