Not much info to go on. Pipe runs straight up? double wall? how tall?
A couple of ideas. Buy a manometer from Yukon for 58.00. Your settings won't change (much anyway) based on some build up on flap.
Make sure your baro is set up for horizontal or vertical run of pipe, vertical on right and horizontal on left (if you bought the same stuff I did from yukon).
If you are guessing and you shouldn't, put the weight almost as far back as possible, then just move it out 1/8 or so inch.
When you say creosote build up, you mean the runny black tar stuff or just some fluffy ash stuff. The runny stuff is from green wood, the other stuff is from cool burning. I'm guessing you have the fluffy stuff that I deal with also.
(I think fluffy stuff is actually the technical term
I can burn the fluffy ash stuff off by hitting 900 or 1000 in the stovepipe once a week or so (very cool to watch that stuff glow and burn off), and keep it way down by hitting 600 or 700 once or twice daily, for sure first thing in morning to burn off overnight idling stuff.
Burn very small fires when it's warm, burn them hot and then let them go out.
I tired bypassing the damper, just put foil over it. It burns a lot more wood. I also think that we have very little chance of the runaway fire that you read a lot about on this forum the way the furnace is set up, but if you bypass the baro, on a very windy day with the right conditions, you could really overfire the whole set up.
That's my $0.02 worth, hope it helps.
johnsopi said:
I have a big Jack wood furnace that has a barometric damper on it. Have been running it four years.
I set the barometric damper by guessing what it should be. I don't have a manometer and if I did the
setting would all ways change because creosote builds up on the flap, because the air cool the smoke.
I've thought of not using the damper but it was designed using the damper.
