Todd said:3fordasho said:Diabel said:Measured with magnetic exterior thermometer.
I like to see mine at around 400*-450* anything below that I consider a less of a clean burn (of course coaling stage not considered here). Over 600* I get uncomfortable & I feel like I am wasting fuel.
Your thoughts:
Seems high. I have a probe type thermometer installed about 2' above the stove. I'll see 400F when charing a new load of wood,
but once the air is cut back and cat engaged it will only run 200-250F.
For chits and giggles could you put your external next to your internal and see what the diff is? I find it hard to believe your running 200-250 internal unless it towards the end of the burn. A while ago I asked Woodstock for some internal temp info and they told me they have an internal probe 6' up that reads 400 on a full load.
I have double wall from the stove to the class A insulated so I don't think my external (surface) thermometer will read correctly, plus my straight sections are telescoping (adjustable) sections so in reality they are more than double wall. I am curious though as my temp readings seem lower than everyone elses. When I get a chance I'll try an industrial digital readout temp controller I have laying around, it has an external j-type thermocouple I could stick into the flue easy enough.
And just for clarification, the internal flue is reading 200-250F with the fireview loaded, cat engaged, air inlet between 3/4-1, and reaching stove top temps of 400-525F.
