Awesome. Good luck.Yes a summit used 2 seasons. If I can get it at the right price I want to try it out
Split right next where you stack, such that every piece comes right off the splitter (or splitting pedestal) to the stack, with no extra process involved. Here's my workflow:I don't mind the cutting/bucking or splitting, but the stacking is what I don't care for. I split a huge pile over the summer, waiting for my woodshed to be built. My woodshed is just about done, and I'm already dreading filling it up
Can you start it by throwing a drill on the flywheel? I've done that on countless small engines over the years when trying to repair them. Btw, this thread is making me want to sit in front of the stove and start drinking.They’re all hard to start, due to the direct drive hydro pump, but ones with bigger pumps are obviously hardest. You can run a lower viscosity hydro fluid, particularly if you’re only using it in cooler weather, and that should help.
You could also convert it to electric start, as I did with mine a few years back. See if there’s a variant of your engine with electric start option, and either buy the parts required to convert, or just swap engines. If there’s no variant of your engine with electric start, then find a replacement that will fit, based on HP, exhaust location, shaft orientation. Make an electric cord set that allows you to plug it into your tractor for starting, if you want to avoid having to mount a battery on it. I made my cord set out of some cheap jumper cables, cutting off the clamps and replacing with forklift batter connectors (50A).
I did this a few years ago, and thank myself every January, when that big pump is full of cold fluid. I only use the electric for the initial cold start, it’s much easier to pull after warming up.
I split where ever I dump the load of rounds or next to the pile of logs I am cutting from. Then either throw the splits in the back of the dump truck and dump it in front of the stacks. Or make a big pile then push it over to the stacks with the snow plow.Split right next where you stack, such that every piece comes right off the splitter (or splitting pedestal) to the stack, with no extra process involved. Here's my workflow:
1. Fell tree, buck to 15 foot logs
2. Skid logs onto trailer, bring home
3. Lift logs off trailer, stack in a pile by year.
4. Then sometime later... park splitter next to where I'll be stacking.
5. Roll log off oldest pile, mark and buck to 18" lengths
6. Roll rounds into bucket of front end loader, lift, drive to splitter
7. With loader bucket parked next to splitter at hip height, swing each round out of bucket and onto splitter beam.
8. Split, let log catcher on splitter fill up with splits
9. Grab splits off log catcher when full, stack
10. Repeat steps 5-9, ad-nauseum
Yes that's my plan going forward, without the tractor to do the lifting for me, that is. I'm just dreading filling up my new 10+ cord woodshed, but after that it should be smooth sailingSplit right next where you stack, such that every piece comes right off the splitter (or splitting pedestal) to the stack, with no extra process involved. Here's my workflow:
I imagine you could, with the right drill, and if on a machine with access to flywheel or output shaft (eg. belt-drive variants). But it seems most commercial log splitters these days are set up with direct drive, most even having vertical engines with output on bottom like an old push mower. No access for the drill, on those.Can you start it by throwing a drill on the flywheel? I've done that on countless small engines over the years when trying to repair them. Btw, this thread is making me want to sit in front of the stove and start drinking.
I did that my first few years, starting with a wheelbarrow, and then quickly transitioning to a utility wagon behind a 50 year old Cub Cadet. Eventually this wood habit and other jobs around the property pushed me to buy a cheap old tractor with a front-end loader.Yes that's my plan going forward, without the tractor to do the lifting for me, that is. I'm just dreading filling up my new 10+ cord woodshed, but after that it should be smooth sailing
That's how I started out too, borrowing a poulan chainsaw from a friend (never again!!) and renting a splitter for a day and running it 16+ hours together with my wife before returning it. I've since bought my own saw and splitter, and I'm finishing up a massive wood shed. I'm in the south so we don't even really get cold here lol. I can definitely see the slippery slope you're talking about, and I'm definitely going down it. However there's much worse ways to spend your time and money so as long as I enjoy it I don't mind. My wife will sometimes gripe about it during the summer, but I never hear a peep about it during the winter and its 76 in the living room lolI did that my first few years, starting with a wheelbarrow, and then quickly transitioning to a utility wagon behind a 50 year old Cub Cadet. Eventually this wood habit and other jobs around the property pushed me to buy a cheap old tractor with a front-end loader.
But that's another slippery slope, I've since transitioned to a brand new tractor that could pick up the first two tractors, together. Not the cheapest means to an end, but toys get bigger as you age into any hobby.
BUT have you ever done the math?My favorite part? Not paying Superior Plus outrageous prices for heating oil and propane. After that, my favorite part is cutting, splitting, and stacking. I get a real sense of accomplishment out of it.
My wife griped the first few years, esp. when I was wasting enormous amounts of time fighting with and constantly rebuilding my old Jotuls. With the new stoves and better equipment, the time investment plummeted, and now she's the first to ask, "when are you going to light the stoves?"However there's much worse ways to spend your time and money so as long as I enjoy it I don't mind. My wife will sometimes gripe about it during the summer, but I never hear a peep about it during the winter and its 76 in the living room lol
Yes, I have. Actually, many times. If you have to buy wood, it's going to make it much less attractive. Likewise, if you were only using $1000/year for your central heating... don't bother. But if your heating costs are over $10k/year, and wood is free with some hours of labor, it's really not hard to save some serious coin, especially if you have a salaried job.BUT have you ever done the math?
Are you buying it at 7-11? You're either paying $1k+ per cord or burning 12" diameter splits.A cord of wood, for me, costs me about .30 cents a split.
