BeGreen said:
I chose one at random, the NC code. However, this is the gas code. It does seem to back the spirit of the international code:
Okay I screwed up by posting the NC and Tempe with the gas code. Quite
random selection you had there. ;-) ;-) I don't doubt that gas or liquid fueled appliances are not allowed in bedrooms.
However here is a different link for NC that demonstrates my point (
http://www.ncdoi.com/OSFM/Engineeri.../approved/2006NCMechanicalCode_amendments.pdf) -
Exception: This section shall not apply to the following appliances:
1. Direct-vent appliances that obtain all combustion air directly from the outdoors.
2. Solid fuel-fired appliances, provided that the room is not a confined space and the building is not of unusually tight construction.
And a different link for Tempe that demonstrates my point (
http://www.tempe.gov/bsafety/BldgCodeAmend/2003_IMC_Amend.pdf)
"1. Direct-vent appliances that obtain all combustion air directly from the outdoors.
"2. Solid fuel-fired appliances provided that the room is not a confined space and the
Oregon -
Exception: The following appliances shall be permitted to obtain combustion air from sleeping rooms, bathrooms and toilet rooms:
1. Solid-fuel-fired appliances provided the room is not a confined space and the building is not of unusually tight construction.
South Carolina -
1. Solid fuel-fired appliances provided that the room is not a confined space and the building is not of unusually tight construction.
Virginia -
Exception:
Also Massachusetts (
http://www.mass.gov/Eeops/docs/dps/780 CMR/780067.pdf)
construction.
Also Illinois ((broken link removed to http://www.elmhurst.org/DocumentView.asp?DID=330))
Also Kansas ((broken link removed to http://www.lawrenceks.org/web_based_agendas/2007/10-02-07/10-02-07h/DS_Ordinance8166_InternationalMechanicalCode.html))
(A) Direct-vent appliances that obtain all combustion air directly from the outdoors.
(B) Solid fuel-fired appliances provided that the room is not a confined space and the building is not of unusually tight construction.
Also Alabama (
http://www.cityofmobile.org/pdf/MechanicalCode2000.pdf)
EXCEPTION: This section shall not apply to the following appliances:
Also Ohio (
http://codes.ohio.gov/oac/4101:2-3) -
Also Washington ((broken link removed))
Exceptions: 1) Direct vent appliances that obtain all combustion air directly from the outdoors,
2) Solid fuel-fired appliances provided that the room is not a confined space and the building is
Also Florida ((broken link removed) Appendix E.pdf)
2. Solid fuel-fired appliances and fireplaces, provided that the room is not a confined space and the building is not of unusually tight construction.
So that's 12 states where wood stoves are clearly permitted. The secrecy around building codes drives me crazy. If they were REALLY about safety they would be publicly available for a nominal cost. I bet there are more states out there that permit wood stoves in bedrooms, but since the code isn't easily available...
