Kenster said:Now I have another question re: our Vigilants. It's the only wood stove I've ever owned and operated. I follow the mantra of burning dry wood. Hopefully 20% or less. But, is that as critical in the Vigilant as it would be in a modern EPA Cat equipped stove?
I'm really going to be in a bind in about three more nights of burning and February is usually our coldest month. I've got almost two cords of split water oak and pin oak stacked out back. A lot of it is off the chart wet but some of it is from the tops of trees that were either twisted off in high winds, or from standing dead. So, the MC is closer to mid 20%-- 25-28. Would it be a bad thing to burn some of this, maybe mixed with what little dry splits I have left?
If you check out my wood drying thread, you can see the results of burning wood that was in the 29% MC range in my Vigilant. Same fire as in my avatar. No mixing with seasoned wood, just straight black birch at about 29% MC right from startup. If these results aren't convincing enough, you're an infinitely better burner than I am.
https://www.hearth.com/talk/threads/67839/
BTW, if you are measuring the moisture content of your firewood with a resistance-type moisture meter, you are already at 20% water by weight when the meter reads 25% MC. 20% water by weight has been the standard for defining seasoned wood for as long as I can remember, and is at the high end of the EPA test loads used to evaluate emissions in modern stoves.
