shmodaddy said:I think ill try a pair of those chains you suggested along with the muffler mod I found in a earlier thread!! I love seeing my neighbors eyes pop out of his head when I blow him away with stuff......lol its a very friendly competition! I'll. Keep the 050 chain and bar in mind when its time for a swap.
shmodaddy said:What is the significance of the pitch? .325 is measuring what
TreePointer said:shmodaddy said:What is the significance of the pitch? .325 is measuring what
See pitch and gauge definitions here: http://www.stihllibrary.com/pdf/SawChainSelection.pdf
smokinjay said:Need a PHD....lol Also keep in mind the cutter on a .325 is smaller than say a 3/8. Then throw in low profile. Can give you a headache after awhile.
shmodaddy said:***banging head on desk**** ok does the pitch relate to different clutch and bar assemblies?
TreePointer said:When buying a new chain, all FOUR of these criteria must be met:
Pitch
Gauge
Number of drive links (DL)
Bar mount type
TreePointer said:The drive sprocket on your saw has a pitch, the sprocket in the tip of you bar has a pitch, and chains have pitch. ALL THREE MUST MATCH. (Exception: bars without tip sprockets (solid nose) don't have a pitch.)
Your bar has a GAUGE (width of groove) and your chain has a GAUGE. BOTH OF THOSE MUST MATCH. (Note that the drive sprocket on your saw is gauge independent; that is, the drive sprocket can accommodate different gauges.)
smokinjay said:TreePointer said:When buying a new chain, all FOUR of these criteria must be met:
Pitch
Gauge
Bar mount type
lol, there you go throwing in #4 stihl large mount. Only matter if your buying a bar.
Flatbedford said:I have been very happy with Stihl RMC full chisel chain on my 029. Mine is a 20" bar so you should have even better results with your 18". Here's a picture of the box and another to give you an idea of what the chain looks like. This is not "safety" chain so you do have a higher risk of kick back when using it.
Also look around this site. I think it will answer most of your questions. I learned most of what I know reading here a few years ago. http://www.madsens1.com/muu_barchain.htm
When you do buy, I recommend Stihl chain.
TreePointer said:smokinjay said:TreePointer said:When buying a new chain, all FOUR of these criteria must be met:
Pitch
Gauge
Bar mount type
Oops, having a brain cramp today. LOL!
Fixed it.
MasterMech said:[Flatbedford said:I have been very happy with Stihl RMC full chisel chain on my 029. Mine is a 20" bar so you should have even better results with your 18". Here's a picture of the box and another to give you an idea of what the chain looks like. This is not "safety" chain so you do have a higher risk of kick back when using it.
That's yellow label semi-chisel chain, not full chisel. RSC chain is full chisel. Been meaning to pick up a couple RMC loops for my 034.
Flatbedford said:MasterMech said:[Flatbedford said:I have been very happy with Stihl RMC full chisel chain on my 029. Mine is a 20" bar so you should have even better results with your 18". Here's a picture of the box and another to give you an idea of what the chain looks like. This is not "safety" chain so you do have a higher risk of kick back when using it.
Oops! I guess I should pay more attention to what I buy. :red: It still cuts very nicely and the 029 seems happy with it.
