I've been looking at this splitter for mostly oak and elm. I'm cutting 10 to 15 inch standing deadwood that is dry as can be and thinking this splitter should be able to handle it. Your thoughts and input will be appreciated.
+1 on that! I was at Northern & they had the 13 ton on a bench torn apart with a wedge that had come off at the weld. Randygeardoc said:Spend $200 more and get the 22 ton Northstar. Had mine for 2 years and no problems.
mayhem said:Switch to vertical for pretty much everything you split. When I borrow a splitter that goes vertical, everything down to like 3" in diameter gets split vertically...if you get a piece that winds up popping it'll just flop over to the ground.
mayhem said:I usually kneel or crouch near the splitter
ezwryder said:And please stop by when you're in the area for a cup of coffee or a snort of apple cider.
