Great prices - and don't forget I think you can get a 10% tax credit this year on the purchase of a new stove too.
Thanks,
Bill
Thanks,
Bill
wendell said:Hmmmmm
metalsped said:I am not big on the styling of the Woodstock stoves.... but this new one is purty!
wendell said:Hmmmmm
BrowningBAR said:Just spoke to Woodstock. If everything works out right, I will have the Woodstock PH in March. Still a few things up in the air.
Todd said:BrowningBAR said:Just spoke to Woodstock. If everything works out right, I will have the Woodstock PH in March. Still a few things up in the air.
That's a long time, are you sure you can wait that long? You better stay off Craigs list until then.
Battenkiller said:wendell said:Hmmmmm
Uh...... Yeah ;-)
Prices like that plus the 10% tax credit makes them close to what you'd be out of pocket if you bought one last year. I came to the conclusion that a Fireview wouldn't work well in my present situation, so I passed on the sale last season. After we were told we had to move out of this place, I got to thinking that maybe a Woodstock stove might be a better fit in the new place when we get it. I would be kicking myself in the backside for that, except now it appears I can still get a great Woodstock stove at a great price. Guess things always happen for a reason.
I doubt I'll be set up to burn this season, but maybe I should get the stove now while it is cheap and store it until I can do the install. The place I'm looking at tomorrow has a barn. Should be nice and safe in there, sitting on a pallet next to the Vigilant. :coolsmile:
Todd said:wendell said:Hmmmmm
Where are you going to put the new Woodstock, upstairs or down? ;-)
Backwoods Savage said:Todd said:wendell said:Hmmmmm
I was wondering that too Todd. How about it Wendell?
BrowningBAR said:Backwoods Savage said:Todd said:wendell said:Hmmmmm
Anyone in Wendell's household need more dental work?
wendell said:BrowningBAR said:Backwoods Savage said:Todd said:wendell said:Hmmmmm
My son is having his wisdom teeth out next month.
. . .The real trick is getting the two different systems to work effectively together and make the stove as simple to operate as possible. Through the long and winding path of R&D we have designed an air damper system that controls both primary and secondary air to the firebox using a single, simple lever. The ratio of primary to secondary air is pre-set so the user does not have to fiddle with separate knobs or levers to fine-tune the burn. The Progress will automatically deliver unused secondary air to the combustor at lower burn rates, or allow the air to combine with gases in the firebox at higher burn rates for a spectacular secondary burn. At a medium burn rate, the secondary flames and catalytic combustor alternate depending on the conditions in the firebox. Two different systems, working in harmony, make the Progress Hybrid.
Den said:Blog update. Confirms what Todd said about 1 control for primary + secondary air. . .+ hints at some mojo. . .
and contains a better name, IMHO, The Woodstock Harmony.
http://woodstocksoapstoneco.blogspot.com/
BrowningBAR said:Why are they still only showing rendered versions of the stove?
So that I will end up spending a kaboodle of money on something I haven’t even seen, and quite possibly go insane from the very idea of doing so…
