So that is why we got that creepy feelings when we stopped for a visit
No, that is not true at all. We may stop again some time.
Sure hope you do! I'll make sure Cap'n Benjamin is on his best behavior. Can't guarantee my own, tho
I hear WS may be looking at increasing the screen's hole size. I went the whole winter last year and only had to clean that screen 3 times, but I've had to clean it after each of the last two shoulder season fires. Both times I burned cottonwood, once when it was damp from the rain, the second time it was dry. But both those shoulder season fires never got the stove very hot, and the screen seemed to clog with wood fibers rather than ash. Waulie makes a good point - we need to separate a marginal flue setup from a clogged screen - they can both cause the same symptoms.
The screen looked like a bigger size to me. It is a lot easier to clean and remove. FWIW- I did have smoke spillage due to the clogged screen before.
There is currently no option for a ceramic Cat in the Progress. I've heard people in general have been frustrated using cat probes for various reasons, so I'm not sure if that would just add another fly into the ointment. For now I am measuring flue temps on the flat steel plate in back of the lid.
Can you explain what you are referring to please? "..the flat steel plate in back of the lid..."
Yeah, I don't follow either. There is a cast "plate" behind the soapstone that regularly measures lower temps for me when then cat is engaged. Actually, I just tried it. 30 degress cooler on the rear cast behind the soapstone. This is "downwind" of the cat so that makes sense to me.*
*Stovetop at 405 after lighting at 9:30 with a 1/4 load and will be warm until tomorrow evening.
I guess my words were not so good - so here is a picture - the plate I refer to is the one that says "Progress". I use the rear mount flue setup.
I have been using this plate to measure temps before engaging the cat. The soapstone lid temperature seems to vary quite a bit, depending on exactly where you measure, and I think this plate may give a better idea of true internal temps. I can't measure at the flue pipe, it's hard to get to inside a fireplace.
Which brings to mind another aspect to consider with re to stove experience - top or rear vent. I'm rear vent & have had issues (back puff, smoke, cat etc)
Hi Everyone. New to forum, 1st post! I've been tracking your posts on the PH with great interest. I have ordered one and expect delivery last week of November. Don't mean to stray off topic of this thread, but wanted to ask if anyone here regrets purchase of PH with these small issues you are experiencing? I'm in need of a new stove and liked all the positive reviews I read on this one. Plus it was one of the select few that could meet my flue requirements (rear exit, 23.75 inches above hearth). My other candidate was Jotul F500 Oslo. I'm replacing a Vermont Castings Encore Non-Cat that is only 6 years old. Fountain assembly disintegrated and cast iron cracked.
Do you have the new screen?
