Todd said:
Slow1 said:
Todd said:
My guess will be somewhere between the Mansfield and Equinox, about 600lbs. Hopefully it will use a 6" flue, since it's much cheaper than 8" and most relines are 6".
I'll go with 725lbs as my guess just because it's bigger and I have nothing else to base my guess on anyway.
As to flue - I too hope it's a 6" - would make it a WHOLE lot easier for us compulsive upgraders now wouldn't it?
Will your wife go for 3 stoves in 3 years? I already have permission, but have to see the stove and specs first. If it's Equinox size it will be too big and my chimney won't work.
Well now... I imagine the answer is likely pretty simple. No.
Then again, I never expected her to go for the upgrade to the Fireview and here I am. However, it really does depend now doesn't it? For example, just what would the cost differential be? What would we get for that? It is, after all, in how one presents the argument isn't it? We're all entitled to our fantasies aren't we?
Truth be told I'm not sure how good it would have to be in order to justify the bother in any case - it would have to have some really special features and be a significant upgrade from what I have now. We had what passes for a pretty cold day around here, low around 7, high in the 20's with some wind keeping it interesting. Started out the day a bit behind/cool in the house so had to run the stove a bit harder during the rest of the day but nobody complained about being cold. Was able to keep a slow but steady temperature rise all day. Not bad for heating over 2200sqft. A larger stove would have kept it warmer overnight I'm sure and likely could have heated things up a bit faster during the day, but I only hit 500 on the surface so I never really maxed out this stove either - still learning how to comfortably jack the temperature up to get even more heat out.
