Ash pans are overrated. This should not be a showstopper.
The ash pan in my PH is pretty incredible! I use to have an old smoke dragon without an ash pan and the ease of use with my current setup is really nice!Yes, it is. I've done it both ways and it's damn near a deal-breaker to me, to not have a grate. At the very least, it has to have a decent ash dump.No ash pan kinda sounds like a pain to me.
Right. If you've never had a good grated system, you don't know what you're missing but once you have used it, you don't wanna go back.I'm not sure begreenThe ash pan in my PH is pretty incredible! I use to have an old smoke dragon without an ash pan and the ease of use with my current setup is really nice!
The Castine system isn't that good if you can't let the ash build up to the desired depth. In the Keystone, ash will sit on top of the grate until you elect to stir it down with a poker. You won't be going six weeks before shoveling out the Fireview, more like six days if you want to get the biggest loads in the box; It's only 1.8 cu.ft. usable volume. If you have an over-sized non-cat stove like begreen, you don't worry about how big a load you can get in since you are burning mostly small loads anyway, so as not to roast yourself out in the mild climate.Our Castine had a good ash pan system, but I eventually stopped using it. The stove actually ran better with a bed of ash under the fire so I let the pan fill up and cover the grate. Ash buildup can also be controlled by the species of wood burned. Some create much more ash than others. By burning doug fir I can go about a month between ash cleanouts during peak season and 6 weeks during shoulder season.
Yes, it is. I've done it both ways and it's damn near a deal-breaker to me, to not have a grate. At the very least, it has to have a decent ash dump.Right. If you've never had a good grated system, you don't know what you're missing but once you have used it, you don't wanna go back.
But whether you have to shovel out often, or once a month, you'll spend about the same amount of time either way, although if you shovel out less often, you can usually pick a colder day when the draft is pulling the dust back into the box better.
Fortunately, Tom Oyen had better common sense. Shoulder season burning days for us are typically less than 30 a season. Usually, the stove is fully loaded and running 24/7 from November through February. I'm not that fond of running partial loads as it means starting once or twice a day so above 45º I let the heat pump carry the load. This year I ran exclusively on wild cherry in Jan/Feb and had to clean the ash out every other week. Doug fir on the other hand creates maybe 1/4 to 1/3 that amount of ash.That's a hole in their lineup, going from 1.8 cu.ft. in the Fv, to 2.5 in the AS. I would love a Ws steel, straight-cat stove, rear or top vent, ash grate and big window, about 2.2 cu.ft. usable volume. Buying a stove is usually a trade-off, you seldom find everything you want in a single stove.I wish Woodstock made a soapstone/steal stove w/ a 2 c. ft-ish firebox-the Survival is too small, and the AS (seems) too big; or that they would put an ash pan on the FV!!
Oh, that's right, you have a lot of glass and not that tight a house, I stand corrected. But heating solely with wood I would have a lot more than one month of shoulder season there, where it is cool and damp most of the year, so the heat pump would no doubt be saving me a lot of shoulder burning, and shoveling. Heck, I burned a half load of Black Cherry yesterday morning because it was under 70 in here and damp, and my wife was chilly.FWIW, the T6 is definitely not oversized for our house. With the exception of some shoulder season burning the T6 is running full loads 24/7.....Shoulder season burning days for us are typically less than 30 a season. Usually, the stove is fully loaded and running 24/7 from November through February.
sugar cookie has Doug Fir and Pine, so maybe wouldn't have to shovel as often. I'd still want to avoid it, but some folks don't seem to mind...to each his own. My point about the over-sized stove was that you can let ash build up a long time, but she doesn't want to risk being roasted out by a stove that's too big most of the time, and the Fv requires more frequent shoveling than a bigger stove in order to get max wood in the box.This year I ran exclusively on wild cherry in Jan/Feb and had to clean the ash out every other week. Doug fir on the other hand creates maybe 1/4 to 1/3 that amount of ash.
Also depends on how far below the door opening the firebox bed or grate is. Some stoves have deeper bellies than others.My point about the over-sized stove was that you can let ash build up a long time,
, but ironically in this instance, he made the final decision and chose the FV, despite the fact that we're on an extremely limited budget. I'm glad he did, since I was having such a hard time making the choice. I was struggling to pay $1000 more for the FV, but he said that it's an investment and we need to make sure we have one we like since we're going to have to live w/ it every day. Yea!I haven't heard this, recommendation to burn higher. You burn the stove at a higher rate when burning in a fresh load and bringing the stove up to temp for the cat light-off. I've never burned either the Ks or Fv hot to burn out creosote..it's just not much of a problem if your wood is dry. I generally do a cat-only burn for most of the loads, no flame in the box, unless it is cold and windy out, when I need more output in our leaky house with un-insulated walls. The double glass stays pretty clean on these stoves, and I'd think the AS wouldn't be much different.The peeps at Woodstock said either the Keystone, Fireview or AS would work for us, but they said they thought the Fireview would be the best fit out of the three-they do seem to think that we would be able to burn it at higher capacity on a more regular basis, which is recommended...They said that it's not recommended that the AS be burned long and slow all the time (which is most likely where we would be at with it), or that, if we did choose to burn it that way, that we make sure we burn it at full capacity, and high every once in a while to burn soot off the glass, as well as creosote buildup.
The footprint of all three is about the same, though the AS has the ash lip on the front. You could get the "Plain" model with no lip but I think the Wildwood looks better.I believe the AS would work, the question we're facing is- do we want to have a much larger stove than we really need (and I mean that literally too, as the house will only have about an 850 sq ft footprint, so we're not sure we want a big 'ol stove in the middle of it,
Don't feel pressured by the "sale," they run them all the time.Thank you, all! These comments help confirm our decision. We wanted to make one by today since the AS goes off-sale this eve...in case we decided to go with it. I think we're going to go w/ the FV despite no ash pan and a higher price tag.
The deciding factors were (In this order):
1) Woodstock, themselves, period. Love this company, so we knew for sure we wanted to go w/ them; and we knew we wanted soapstone in the stove in some way, therefore this seemed like a win-win.
2) "Perfect" size for our space/long burn times/hopefully no cracking windows
3) Favorite look
4) Double layer of soapstone (like that type of warm, radiant heat)
5) Soapstone/cast iron (preferred) vs soapstone/steal
My husband is usually the cheapskate, and I'm the one who is willing to pay for quality, but ironically in this instance, he made the final decision and chose the FV, despite the fact that we're on an extremely limited budget. I'm glad he did, since I was having such a hard time making the choice. I was struggling to pay $1000 more for the FV, but he said that it's an investment and we need to make sure we have one we like since we're going to have to live w/ it every day. Yea!
![[Hearth.com] Woodstock Absolute? [Hearth.com] Woodstock Absolute?](https://www.hearth.com/talk/data/attachments/243/243984-3df5ee86f771ca5ff0d5bd86b7f9bbf9.jpg?hash=jzp6XpYeh4)
!They also have some of the most reasonable parts prices you'll find.stove should last, and the company is great about helping out. Your good feeling about the folks there is right on the money.
