Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
Looks good. Hoping it is just a optical illusion, but the floor rail at front looks to already be sagging on the ends(bowed). Do you have runners on each side also, or just the middle two?
If just the tow in the middle, once loaded that floor might gas on each side pretty bad.
It has most of the load at the rear in this photo. I have since put a bunch more towards the front which should help balance the load. The skids are pressure treated 4x4s. They are resting on concrete mix to get them level. Hope this helps.
A cord of fire wood is 4'x4'x8' which is 128 cubic feet. This wood bin shed will stack over 4 cords of firewood which is 512 cubic feet. From the plans. #math
If the walls are 8 ft tall it should hold closer to 6 cord. The math is 8X8X12=768 cubic ft, 768/128 (one cord) = 6 (cord).
Of course that is assuming those are inside measurements, but if your 8x8x12 is the outside measurements you'll loose a bit because of the thickness of the walls, but either way, if you stuff it full you should be able to get a full 5+ cords in there. However, even with slated floors and the bit of ventilation on the soffits it still wouldn't be ideal drying conditions with all the wood packed so tightly together.
