Gooserider said:If the gasket doesn't want to stay seated, you could try putting a little bit of high temp silicone caulk in the groove before you put the gasket in. Then put a strip of aluminum foil over the gasket and close the door to make sure everything seats properly while the gasket goop dries. The tin foil will act as a "release" to keep any ooze out from gluing the door shut.
Gooserider
Hi Jarvis!!
This is what I did. Only I didn't use any foil. Just a little bit of High temp (RTV?) Silicone. No more troubles with the gasket. I did this on both the main door and the ash door.
Glad to hear you got her up and running. The smoke alarm game from the shop coat on the stovepipe is fun!! I had the same thing but only got one of my smoke alarms as mine are not linked to each other. That Goodman gas furnace is nice. I've installed quite a few of those. Hope you're happy with your setup ... I'm sure you will be. Thanks for the update.
Charlie
