Mcbride said:gapman789 said:DWW68 said:just like the rest, not a pro. but i will piont out what i see.
1 support
2 slope on horizonal pipe
3 Stove with 8" flue running into a 6" chimney
4 should have connector to join single and double wall pipe
5 clearance issue with single wall pipe
a roof support could be used if chimney needs to go higher
not to say you cant get a fire going in the stove and have it work, but things could be made a lot safer
good luck
Duly noted.
I will fix the support with a concrete footer 24"-30" deep.
I will remove the pavers from under the stove legs giving me approx. 5/8" of slope per ft.
I'm going to get the correct piping/connector for the flue going into the 6" chimney.
As far as the clearance issue with the single wall pipe goes: Are you referring to the distance of the stove from the wall, or the amount of the double wall pipe that is protruding thru the inside of the wall? There is about 4" of double wall pipe coming thru the wall. The 8" stove pipe is sleeved over top of the double wall.
I do have more double wall pipe that I can use for the flue? I feel that would take away some of the heat that I would be getting from the stovepipe itself.
Definitely don't want to raise the chimney any higher if at possible. How will I know if the chimney isn't high enough? Fire won't burn worth a damn?
That roof has minimal pitch on it. If I measure over from the cap to the roof, I have every bit of 10'. Or is that a non-issue?
Thanks for the advice guys. That's why I haven't fired this thing up yet.
Not too sound picky, but is 24 to 30 inches going to get you below the frost line for your area?
If not go deeper, the bottom of any footing has to be deeper than the frost will go to stop heaving.
Nice bikes!
Yea, 30" is right at the frost line in my area. Southwest Ohio (cincinnati). Maybe I'll go 31" to be safe. lol
I've never seen it where the ground froze more than 16" though. Of course it could happen, and if it does, I'm moving south to at least Tennessee.
I've 21 yrs. exp. in all things concrete...wish some of that experience was in wood burning stoves.
Thanks for the headsup, and my poor bikes are still cold. I'm taking care of the stove issues today. Weenies on the barbie tonight
