I have only two questions, how did you get that picture so clear and detailed? And can you give us all lessons? I can almost see a run in the paint. That is without a doubt the best picture I have seen on this forum, and one of the best on any newslist.
Almost lost track of the thread.
ls
ls
kncrsr5r said:(broken image removed)
Holy big picture....
So the stove has a angled ceramic plate above the fire chamber that sits low in the back and high at the door. There is a 2 1/2" air gap at the front where the smoke heat and gases turn up and head back to the flue. This is the re-burn chamber. It has air passages that direct heated gases back into the fire chamber for buring.
So when I first light off the stove...all the heat and smoke is directed to the front of the stove. With the door open...it comes right into the room as thats the path of least resistance. With the door closed...smoke still leaks out the air inlets above the door. Enough to smoke out the room VERY WELL until the hot air pushes the cold air plug up and out.
The stove is made by vermont castings. Sold under the Century name at Lowes. Its a great stove...Like my original post said though...I just need to figure out how to preheat with out smoking the home out. I dont mind a little...but when cant breath...nah...thats more than anyone would want inside their home.
