We rarely have power outages here. If it did go out I would just plug the pump into a UPS off the computer. If it stayed out I have a small generator.What powers the pump in a power failure?
It is a hearthstone stove. I would have drilled the side and had the coil exit there, but I did not want to damage/alter the stone. By exiting through the top plate for the non-used chimney vent the stove is unaltered.Is that a Mansfield? I did not know that comes with a rear vent. How dry is the wood you are burning?
My original plan was to add baseboard heaters in my basement to control overheating. I have had the system for over a year and have never had the water in the tank hit 120 degrees yet, so abandoned the idea.I would really like to do something similar in my basement. That way I can heat the basement with the stove and also supply hot water to my 1st floor baseboard heaters
I just worry about the whole explosion potential when the water turns to steam.
Was this a water heating kit? Or all homemade?
I am not sure I understand the question. Are you referring to the water preheat tank?This intrigues me. As a total newbie to this idea, can you explain why not to just run a coil of pipe in the air duct that feeds right to the existing water heater?
I had the stove for over a year before I installed the coil. I could not bring myself to drill the stone. My original plan was to go on the rear and hide everything. I settled for entry through the unused top chimney plate. I made a new plate, drilled and powder coated that. I then made a template for the coil and had a friend bend it. He got the size perfect. Then I added the check valve and guages. The tubing on the stove is 3/4", the delivery pipes to it are 1/2". This makes the water capacity a little extra as it warms up. The thermostat is a few inches away from the exit point on the stove to help prevent short cycling on the pump.I really like your ingenuity. However, if I did something like that to my Hearthstone Equinox I'd be committing adultery to a really beautiful stove. Just can't see me doing it.
if there was a worst case and there was boiling the expansion tank would absorb it.
It's good that your power is reliable. Hopefully the power goes out when you are home and not away. Locally I wouldn't trust it and would invest in dedicated UPS that could run for at least 2 hrs. What safety systems have been built in?We rarely have power outages here. If it did go out I would just plug the pump into a UPS off the computer. If it stayed out I have a small generator.
My wood is usually dried for one year. I burn whatever wood I can get, usually a lot of fir, hopefully alder.
When I first installed the system I did have a dedicated UPS on it. When I tested the system for overheating I had it burning for a long time, without circulation, and did not even come close to the overheat temperature. The UPS failed and I just never put one back on it, figured if necessary I would just move my computer one onto the system temperaryly.It's good that your power is reliable. Hopefully the power goes out when you are home and not away. Locally I wouldn't trust it and would invest in dedicated UPS that could run for at least 2 hrs. What safety systems have been built in?
I have not, just as I would not tell them if I modified my kitchen or if I modified my car. An interesting part of this part of the conversation is I work for a City, am friends with the plumbing inspector. I asked him his feelings on the system and he told me he rarely sees these systems anymore, but used to work for a smaller more rural town. He said he used to see them all the time and he would have no problem with them.Have you informed your insurance co. that you have modified your stove? I can guess what mine would say!
the ability to instantly boil a gallon of water would take a tremendous amount of energyNo, it would not. Water flashing to steam results in a huge expansion of 1600 times. That's 1600! So the one gallon of water in the coil can become 213 cubic feet of steam all of the sudden at the boiling temp. 213 cubic feet is like a single car garage with a ten foot ceiling.
The speed at which it expands may exceed the speed at which it can exit through the small pop off valves and/or half inch pipe.
These are the reasons that boilers are certified and your stove mod is not.
They are not required to pay if you purposely modify a ul listed product voiding its listing and making it potentially unsafe. Believe me they don't have to pay in that case i have gone on enough insurance evaluations to say that with absolute certainty.They are still required to pay any claims that happen on your house,
Ok but don't complain if something does happen and your insurance company doesn't pay up.I am personally a Libertarian who just wants to live life without asking the permission of a certification agency in the government for permission in life.
By looking at it it looks like you have done it pretty well and it is probably pretty safe. but when you say your insurance company is required to pay that is just not true.Again, I have tested this system
