I live 75 miles from a Menards store and I make the trip to town once a month for supplies but up here I have to travel for everything. My stove is nearly the same thing as the Escape 1800 in their ad. 2.3 CF box, and it's a non cat.Do you live close to a Menards store up there in Wisconsin? They have a 11% off rebate going right now.
Some good deals with the 11% rebate.
http://www.menards.com/main/heating-cooling/stoves-add-on-furnaces/wood-stoves/c-6884.htm
Like you said earlier begreen, I'd think that he would need to bore into the chimney and put a thimble above the two foot arch. A rotary hammer would make a hole for it. That is if he installs it. Update- I mean if she puts it in... As noticed on Squeaks. profileStoves either vent straight up (top vent) or horizontally directly out the back (rear vent).The cheap stoves at the local big box stores are typically top vent. I am not sure you are going to find a rear vent stove that will provide good heat for under $1500, but that would be the easier installation. Another alternative would be an insert. We need the actual inside dimensions of the firebox in the fireplace to see what insert would fit in there. That would be the most trim installation. We will need the inside width at the hearth level, the inside height, depth top and bottom. While the TV is out of the way for this, take a picture of the fireplace with the doors open.
 )Hey! Thanks for all the replies! Maybe modifying the existing fireplace is the way to go, or putting a stove in its spot (I'll see if I can add a pic of the fire place from my tablet in a bit).
There is a Menards quite nearby. I'll take a trip there this week.. maybe not tomorrow.... it's going to be ridiculously cold. There are also a couple of stove-type businesses in town (I'm quite close to Green Bay). I'll stop in there and see what ideas they might suggest. Thanks again!
(hermancm: your little stove is bea
I also live in NW Wisconsin.A couple of acres won't supply you with a sustainable amount of wood but up here wood is plentiful and I get all of mine from lot owners within a few blocks from my home and maybe you can ask aaround and find scrounge wood too. I put my Drolet wood stove in 3 years ago and its the best thing I've done to the house. I thought about putting it downstairs at first but to monitor the fire and enjoy the heat better not to mention the savings from not having to install the additional class A duct vents out the chase was the way to go after some thought. I bought my stove on clearance at Menards in Rice Lake for $599. Its not a popular brand here but It works great and can heat my 1700 sq ft of upper levels and radiate it to the basement as well on even the coldest of nights but tomorrow night will be the real test at -35 to -static.Chow View attachment 122894Your TV's not big enough.......and makes your stove look like it's sized for an ice shack. Hey, whatcha doing with the propane torch slung over the chair?I also live in NW Wisconsin.A couple of acres won't supply you with a sustainable amount of wood but up here wood is plentiful and I get all of mine from lot owners within a few blocks from my home and maybe you can ask aaround and find scrounge wood too. I put my Drolet wood stove in 3 years ago and its the best thing I've done to the house. I thought about putting it downstairs at first but to monitor the fire and enjoy the heat better not to mention the savings from not having to install the additional class A duct vents out the chase was the way to go after some thought. I bought my stove on clearance at Menards in Rice Lake for $599. Its not a popular brand here but It works great and can heat my 1700 sq ft of upper levels and radiate it to the basement as well on even the coldest of nights but tomorrow night will be the real test at -35 to -static.Chow View attachment 122894
squeaky doesn't really fit the description of 'lady', but, yes, it is female
Hermancm, I just love your little arrangement. I have a spot (you can see it, barely, on the pic on page 1 of this thread, of my upside down living room - underneath the picture of my much-loved, deceased dog), between the gated fireplace and the garage door, where I could fit a pretty little stove like that (I think). It would of course require the addition of it's own chimney. BUT! would allow me to keep the tv where it is. Our living room is pretty tiny and space is somewhat limited (I mean, I could shed a couple of book cases, but... that might kill me...)
