Hi all, I am just finalizing the installation of my new Ashley Hearth Fireplace Insert. A bit of background: I have an old stone fireplace with a 20 foot chimney chase. the chase is lined with clay, but am unsure of the condition of the clay. I installed a 20 foot flexible steel liner ( flexible really seems like a poor descriptor!) and insulated the first 16 feet of the liner (from the stove up) with a 1 inch thick insulation blanket from Rockford Chimney Supply. I am now trying to seal off the throat where the damper used to be ( I removed the damper to get the liner through) using a home made damper block off plate. To seal off, I cut out insulation blanket (rated at 2600F) in the shape of the damper with the liner hole cut out, and then did the same thing with a 20 gauge steel sheet of metal. Essentially was trying to make an insulated damper block off plate.
Questions:
1- Do you foresee it being a problem that the top 4 feet of the liner is not insulated? For reference, those 4 feet are in the part of the chimney that are above the structure of the actual house.
1a- if you think it is a problem, what's the best way to resolve *without* having the uninstall everything and pull the liner out.
2- I am having a really hard time attaching the steel sheet to the frame of damper which is made out of cast iron I think. My current plan is to use rutland furnace cement, however that stuff has to cure at 500F for an hour. Do you think that area will get that hot? I tend to think not.
2a- If the cement isn't a good solution, any other ideas?
Thanks everyone!
PS-here is a photo of the finished project. Will be undoing the hearth surround panels to finish closing off the damper once I get feedback from you all on best way forward.
![[Hearth.com] Wood stove rookie--questions on damper seal and insulation [Hearth.com] Wood stove rookie--questions on damper seal and insulation](https://www.hearth.com/talk/data/attachments/299/299000-fb72b0bc2461722fbb763eaa42eaec2c.jpg?hash=vBCJBFeLeK)
Questions:
Thanks everyone!
