If one lives on a windy ridge like you do, less than 3 yrs. might work for Oak. My stacks are in the shady, damp woods where the trees block most of the wind. Once I get to two years, I keep waiting.
I would give eco bricks from tractor supply a try/ test run. If they burn well you know your draft/ air supply is ok. I started burning one or two with some of my less than perfect wood. Just found out that my TSC won’t be getting any more pellets this season and I would guess that means eco bricks too.
The most dry wood I burned in my 1988 VC was aged 6 to 8 months. That was what I lit the fire with, using pine kindling.
As I said the stove loved that wood no dark glass. Cleaned the pipe once a year not too much creosote.
You must bear in mind this was not Minnesota. This was central Georgia with a cold day being 25 degrees.
The covers blew off my 'dry covered wood' and now I'm burning through six-year split Red Oak that's wet. Gunking my window, and I gotta open the door as I'm burning in a new load, to see how much the splits are sizzling. Luckily, only about 1/3 cord to go. Hey, I better check on the stuff that's next in line!
