I am by no means saying you are wrong on either count I just don't see that it is worth fighting with rigid and as a pro I feel I need to use tested and approved products and I will always recommend that to others
I have no doubt that it is safe and probably exceeds insulation requirements but with out a ul label an inspector could fail it. I agree about rigid being slightly more durable but we use heavy flex which is made from .015" metal I don't think that using rigid is worth the extra trouble for the slight advantage in thickness.
I agree with most of what you said completely accept that rigid is safer than heavy flex I don't think there is any difference in safety between the two. I do see a potential problem with the rigid in that due to the difficulty in hooking up the joints in the offsets it is very possible that you may not get them completely together which could be a safety issue further down the road. Also what brand of insulated chimney did you get 16' of for $220 that is one hell of a deal
From what you're saying it doesn't sound like the savings are all that significant for the liner. I ended up paying $385 for a 25' liner, appliance connector, and rain cap, with no tax and free shipping. Granted, I had to negotiate a little over e-mail with the ebay seller, but given how much longer my liner was and the inclusion of the rest of the kit I think I did well, and without the hassle of piecing together multiple lengths of rigid liner.
Where your advice could have definitely saved me money would have been in the insulation, but if that's 2 inches thick it wouldn't have worked well for me anyway. My flue was 11" x 11" and it was hard enough to cram the liner down it as it was. Adding insulation that thick would have made it practically impossible.
On that note, I may buy some roxul and line my firebox with it.
what's the thickness of 8in liner purchased for $385 shipped?
when shopping what I found were mostly flex liner kits with .007in thickness stainless.
no question flex liner will be easier to install vs rigid ..
not everyone has the luxury of having access to a fireplace warehouse with decent inventory.
same for large commercial building supplier that stocks correct high temperature insulation.
mineral wool insulation rated at 2000f comes in several different thickness/shapes including 1in rolls.
Lowes can order correct insulation but they will need help in finding part numbers/descriptions.
yes .. mineral wool rated to 2000f is material used for liner insulation. follow link in above post for rest of details.
Here is a link to a product that is intended for chimney liner use. You will note that it specifically states a max continuous operating temperature vs a melting point.
http://www.morganthermalceramics.c.../kaowoolblankets-kaowoolblanketszrenglish.pdf
my liner is insulated to be safe in excess of 1,100C with added safety of being inside a masonry fireplace several feet thick.
