Is it possible to put a wood burning insert in this basement corner (if I demo the current setup since it’s drywall) ? I am aware that I will need to essentially demo the existing drywall and build a masonry fireplace and then put the wood insert in that new fireplace.
Why? The current fireplace is gas. It does not heat very well , is old and needs repairs frequently, so I am looking to get a wood burning stove insert instead. We wouldn’t have to use it every day, but I imagine we would use it a few times a week.
Ceiling is 7 foot 2 in. Main heat source in house is an electric heat pump with aux heat source of oil if it gets really cold.
Note: I would rather not go with a freestanding, wood-burning stove option because I prefer the look of the fireplace insert and in the small basement space it works better with the layout.
Also, I know I will need new vent pipe and double wall pipe going up the side of the outside of the house for the chimney. In this side of the house there is no existing masonry chimney to use.
Vent outside from existing gas fireplace
Is it possible to use this existing hole as the spot for the thimble and then run up the side of the outside wall with double-walled pipe?
![Wood stove insert in basement fireplace rebuild? Wood stove insert in basement fireplace rebuild?](https://www.hearth.com/talk/data/attachments/323/323486-0d6397c1eef586da2039a83cf6566b45.jpg)
What do you guys think? I do have a fireplace company locally that’s going to come out and take a look.
![Wood stove insert in basement fireplace rebuild? Wood stove insert in basement fireplace rebuild?](https://www.hearth.com/talk/data/attachments/323/323485-6e7f6375000b00ba23cff2577609e2b7.jpg)
