I am wondering if I may have draft issues with a new build.
Daylight basement, with the stove on the dark side of the basement. Chimney will go straight up next to the peak of the roof. No bends.
There's probably no way to use outside air in this configuration. I've heard that basements, even daylight basements, can be tricky with wood stoves.
Am I probably fine, or is it likely I'll have problems?
Thank you!
Thank you!
