nickn said:
Hello in a couple of weeks I’m getting a wood burning insert installed. I’m already looking for firewood, I think this season I’m going to need to buy 2 cords of wood and at the same time start scrounging around for firewood that needs to be split for the following season. I have several questions: The first is what the best wood to buy and how should I store the seasoned split wood that I will using this season? The second question is: The wood that I will be gathering up for the following season how should I store it? Do I need to cover both the seasoned split wood for this season and the unsplit wood I gather up for next season? Also do I have to store the wood in a sunny area or could it be in the shade? Thank you for all your help. I’m a true rookie from North West New Jersey about 35 min form NYC.
Congratulations on becoming a wood burner and welcome to the forum Nick.
If you've done any searching on this forum and by the comments you will be receiving, you will know that the best time to get the wood you will need to burn this winter was last year or the year before. All wood needs time to dry and there are various ways of drying that wood. Also, one of the first lessons you will receive is that no matter where you buy wood, the wood seller will say the wood is ready to burn; it is "seasoned." The second lesson you will learn is that what the wood seller told you is pure baloney (in over 99% of the cases).
All wood is different and in time you will know how to tell one type of wood from the other. Some wood will season fast (soft maple, white ash and a few others) while on the opposite end of the scale might come red oak or something in the red oak family. We give a minimum of 3 years to season red oak but we can cut soft maple or white ash in the fall or winter, get it split and stacked and will burn it the following winter.
In your case, all you can do it to try to get as dry of wood as possible but I would definitely stay away from oak for your first 2 years, simply because it won't burn worth a hoot and you could have some serious creosote problems and last but not least, you will wonder why people say it is so good because you will still be cold in your house.
As rdust stated, you might get some white ash that could get you through your first winter, especially because so many ash trees are dead or dying.
This brings up another point. Some folks seem to think that if a tree is dead, the wood will be dry. That is not necessarily so! Most of the top of the tree might be okay but the bottom half will usually still be full of sap.
Here is how we approach our wood:
1. We do all the cutting in the winter months; December through February. In March and/or April we do all the splitting. Immediately after the splitting has finished, the wood gets stacked. Before stacking the wood though, we'll cut some small saplings from the woods and lay these down to stack the wood on. You could also use 4 x 4's, landscape timbers, or pallets. The main point is to stack the wood so it does not touch the ground. You want some air circulation under your stacked wood.
2. Stack the wood where wind and sun will do its thing. If a choice is necessary, choose the wind over the sun as the wind will do most of the drying. Stack the wood so that the wind hits the sides of the piles and not the ends as it will do a better job of drying.
3. Don't stack the wood too high. Many do and then have problems with the piles falling over, especially after frost heave or high winds.
We stack our wood 4' high (actually we start at 4 1/2' but by fall the stacks will be down to 4' because of the drying and shrinking of the wood).
Notice the poles under the wood stacks. Also notice we have stacked 3 rows of wood before leaving a space. If we needed that wood the following winter then we would stack only one row then a space and another row and another space, etc. This wood that is pictured was cut a couple years ago and is still sitting there with the top of the wood covered. NOTE: only the top is covered and not the sides of the piles.
A few folks won't even cover the top of the wood pile (we have some that way right now). Some cover the wood as soon as it has been stacked but we never do. Leaving the wood uncovered the first summer and fall allows for a bit better evaporation but we do like to cover it before it gets covered with snow. We never cover the sides of the stack as that would not allow for any drying; it would actually hold the moisture in.
I also recommend everyone should have a 2-3 year wood supply on hand at all times.
Good luck to you on your first year's burning.
One other recommendation I will make to you is to check your chimney every other month as a minimum. Do this for the first 2 years burning. Hopefully after that you will not have to check so often as your fuel supply will be much better. How much better? We've burned our present stove now for 3 full winters and have cleaned only once. We got around a cup of soot is all. That is because of good fuel and an excellent stove along with good burning practices which was learned over a period of a few years.
