Cal-MI said:
			Nope, burning green wood produces creosote.
That is a half truth, which is a lie. Burning green OR dry wood can produce creosote. What is required for creosote formation is that the temperature of the flue be below the dew point of the fumes. Whether the wood is green or dry is irrelevant. Then it condenses on the inside of the flue.
In an ordinary stove, green wood produces more heat per cord, and less creosote than dry wood, according to the USDA FS wood laboratory, under their test conditions with a wood furnace. But apparently the Forest Service wood laboratories has not done any tests in the last 20 years to confirm this. The latest FS literature I could find on it is quite old. Since airtight stoves have come into wide use more recently, YMMV.
Probably some new stoves heat up the flue more quickly than others. For example, 30 years ago an eight inch or larger flue was standard. Now apparently it is 6 inches.
