I would agree with lobsta, AND the hearth depth looks to be at a minimum. if you are keeping the carpet as is, i would consider the loading orientation of your stoves that you are looking at. that is if the hearth depth is sufficient, nonetheless, if there is a chance for EW loaded logs to roll out, they will, and you will be dancing around to keep the carpet from melting. I would go with the PE (biased opinion) for the NS loading alone vs the two door Jotels.
