Think I am going to make some more racks too and truly get 3 to 4 years ahead so I don't have to use a moisture meter ever again.
That is the best plan!! IMO
There's a rule of thumb that wood dries twice as fast for every 20 degree (F) increase in temperature. Based on the monthly average temperatures for my area, that means the drop in MC over the course of a year looks something like this:
So drying is dramatically faster in the summertime; one July is equivalent to almost five Januarys. Your sixteen months only include one summer, which isn't all that much time if drying conditions aren't ideal, e.g. sheltered / shaded / not covered. Sixteen months that began in the spring would be a lot better, because the wood would be drier to start with and you'd have 2 summers instead of one.
It's a rule of thumb, not a law of the universe. It's likely to be less accurate at extreme temperatures, but it's worth noting that wood does dry some even when it's very cold (well below freezing).So, at 20 degrees fahrenheit wood will dry twice as fast as at 0 degrees. Same goes for 200 degrees versus 180 degrees.
That's generally true, up to a point. Wind can quickly dry off a stack of wood that's been rained on, and in still air, relative humidity immediately around the wood surfaces can build up and slow drying considerably; some air movement is necessary to keep the moisture leaving the wood moving away from the pile. That doesn't mean a 20mph breeze is twice is good as a 10mph breeze; it isn't.Plus, most on here say that wind is way more important than temp
Those experiments have been done; that's where the rule of thumb comes from. I'm parroting it from a professor of wood science who posts on another forum I participate in, and I think the same figure can be found in some government publications on wood processing. Anyhow, it's a widely used approximation.I think you would have to do some sort of experiment to convince me that every 20 degrees in temp makes wood dry twice as fast.
I don't recall that being said here. I have seen the statement that wind is more important than sun. I believe that the temp of the air is huge. I might have the time and energy to research that...most on here say that wind is way more important than temp
This is some great info thanks. I'll pass this on and the guys will think I'm very intellegentThere's a rule of thumb that wood dries twice as fast for every 20 degree (F) increase in temperature. Based on the monthly average temperatures for my area, that means the drop in MC over the course of a year looks something like this:
I don't recall that being said here. I have seen the statement that wind is more important than sun. I believe that the temp of the air is huge. I might have the time and energy to research that...![]()
Thank you. I was so proud when I figured out how to plot that curve...
The wood in the pictures is Black Willow, not Black Locust. Look at the width of the outer growth rings. No Black locust grows that fast when it is large. Black Locust grows fast when small but slows down as it gets larger. Black Willow (the common large, wild willow across the east) grows fast all its life. In addition to the growth rate, I don't think the wood has the right color for Black Locust.
I tend to agree with it not being black locust. I don't know what it is but I just bucked and split a cord of Black Locust in the last few days and that is not it. Pictures aren't always great for identification, but give us some end grain and more bark pictures.The wood in the pictures is Black Willow, not Black Locust. Look at the width of the outer growth rings. No Black locust grows that fast when it is large. Black Locust grows fast when small but slows down as it gets larger. Black Willow (the common large, wild willow across the east) grows fast all its life. In addition to the growth rate, I don't think the wood has the right color for Black Locust.
My guess is Hickory ,and it is only a guess because there is just not much to go on in the photos.
