You say that like its a bad thing...
If you have never had a stove with a window then you wont miss it...but if you have, then you will...I do.
But yeah, most of the time you just load the firebox and walk away....with a proper heat load it could/would be that way for sure...but OP may be a bit like me in that my house doesn't require mega BTU's to maintain temp, plus we have had a couple pretty mild winters since my VF100 install...anyways, since I am often running at about the bare minimum I am often scrapeing around for the last few coals to get things fired off again, so sometimes I will sit there for a few minutes to make sure the fire takes off.
OP's house being 2000 ft of new build it may not have a high heat load either...but, he is also in what is typically a little colder area though too. I would still want to discuss with Lamppa the possibility that a VF200 would be a better fit than the larger VF100...I assume the VF200 will be re-released here shortly,
@lampmfg ?
