brenndatomu
Yeah, you'll probably need to leave the key damper open this time of the year (temps too high outside) You may be able to close it a bit more in cold weather, but I'm not sure you really need it with your over-sized (likely) exterior chimney. The best thing to do would be to get a Dwyer Mark II manometer, hook it up to the pipe permanently, then you'll always know exactly what you draft is. You can find a used Dwyer Mark IIs on fleabay for $20 or so if ya watch for a bit, I have bought two like that.
EDIT (there are at least two candidates on there right now, just make sure you get one with the red gauge oil and the hoses included, unless it is really cheap, then you could get the hoses locally. Could just use any ole tubing, but FYI the oil is kinda pricey to buy by itself though.)
