Now for the naysayers. We got a bit over an inch of rain last night. More on the way by the looks of things. Believe it or not, we are above average rainfall for July. Did it come too late? For some things, yes. For others, no.
What do you northern boys consider hot weather? We haven't had a day with a high temp under 96 for 7 weeks and we've been over 100 for the last 10 days straight with no end in sight. 108 today but it's supposed to warm up tomorrow and hist 112 or better for the rest of the week. Humidity runs into the low 40% range.
Most of what I cut last season was either standing dead or had been bulldozed and down for close to a year.
As a rookie I'll still be testing it to see what I'm getting.
News was discussing that the Great Lakes water temp is quit a bit above normal.
Not sure what that will cause, More Lake effect snow this winter ?
Dave, apparently you're a bit of a weather geek too? Local weatherman has a blog that is quite active. I've been reading model forecasts for this coming winter, & many people looking up & prognosticating from analog data. So far it's about 50/50 on either another mild winter, or colder than normal. Colder would make early season LES, warmer might mean more clouds & lake effect rain showers depending on wind direction, frontal systems, clippers, etc. The 2 models that called last winter the closest were discarded in favor of the others. Those same 2 models, the japanese & north american are both calling for cold & snowy patterns this winter. Last winter our precip was above avg. but so were temps, so more rain. I have no clue, but there's the La nina going to weak el nino, upper jet stream shift, Greenland blocking ridge, yada, yada, yada. Bottom line is I make sure to have plenty of wood, clean chimney, & the plow on the truck, & then look out the window in the early morning to see if I need to plow the lot before I open. I do a lot of plow & truck repair in the winter, so here's hoping for more snow than last year. Ask me in March, & I can give you a really accurate winter forecast.Hope that post didn't put you to sleep. A C
No wonder your wood don't dry out up there if it doesn't get any warmer than that.
In January I was cutting wood with temps on the low 70s.
Its still too early to forecast the weather pattern but either weak el nino and a stronger one it usually comes down to the NAO for causing the most wintry weather, A -NAO (greenland block) will bottle up the cold weather in the north/northeast USA. Too early to tell but if I had to make a guess I would go with a colder winter than last year based on current models.
Dave gives me too much credit (check's in the mail, daveLots of "Good examples".
That's why it said on here. "Wood only starts to season after it is CSS (Cut, Split & Stacked)
(some exceptions for some species of long standing dead trees)
Better seasoning if it's off the ground, with good air circulation & space between the rows.
Best (the "Gold standard") is like Papadave does it, off the ground in a single row, but you need a mile long field (& a laser for straightness) to season a few cords:
Papadave's seasoning stacks:
& it still takes "time"![]()
So why do you need firewood???
We don't always get that. Winter before we had record breaking snow fall and record low temps of -30.
Usually we get something in the middle.
Good question as I usually only spend time looking at models in fall and winter as its my favorite and most exciting time of the year. Looks like its broken here in the northeast, its cool out tonight and looks like 70's all week.Hey weatherguy, thanks for the reply, I'd forgotten to apply a little common sense to your handle on the forum. As you've no doubt figured out by now, I know nothing about forecasting the weather, just fascinated by the science behind it. Appreciate some real insight from someone that has experience.
Now I'm gonna tease ya little. A colder winter than last year forecast is prolly a really safe bet for this winter, at least around these parts.When in your estimation might this hot pattern break down for our area? Thanks. A C
It wouldnt be out of the question to have another mild winter but it doesnt look that way at the moment. I assume you get the majority of your snow from lake effect?
In a "normal winter" yes, for some reason we seem to miss out on the big synoptic snow events for some reason. Same with a lot of severe weather events. Many here call it the lake michigan storm shredder. I call it good fortune mostly, les is very light & dry, easy to plow & shovel in comparison to storm snow. 20* with sunshine after a few inches of light fluffy snow is just beautiful in the winter. A C
Whats you yearly avg for snowfall AC? We average 70 but some winters get 100 and some we get 40, with good blocking and a weak nino we usually clean up, we can get in a pattern where we get storms every 3-4 days, its awesome, Im in heaven after a good 2-3 footer, its like a holiday.
They said that last year about the Great Lakes, if it all comes together certain areas will get nailed.News was discussing that the Great Lakes water temp is quit a bit above normal.
