My goodness Shawney, your hands are on backwards. Learn to throw a baseball. You would be un-hittable.shawneyboy said:here is what I use....
WoodNStuff said:For loading my wood to bring it home. What do other wood haulers out there use to load your wood?
WoodNStuff said:CTwoodburner, I know what you mean about the leg burn but at least I don't have to worry about the backache.
firefighterjake, do you really handle your wood that much? Drive wood chunks using my good ole dolly from the the ground to the trailer. When home place wood directly into the splitter from the trailer. Toss splits directly into wheel barrow. Drive wheel barrow to free pallets in the backyard and stack neatly. Then when wood supply is low in the house. Fill wheel barrow with wood. Drive wheel barrow to backside basement window. Open window and toss splits into wood bin located in the basement. When fire low, walk downstairs into basement and retrieve a handful of splits.
Wow, I handle my wood a lot also. On the up side, I get great outdoorsy exercise without paying $99 a month to get it.
Peter SWNH said:Here's that I used when I would fetch milling logs. 6x12 dump trailer, Warn 3700lb winch, and a couple ramps. Wrap the line over top of the log and back to the trailer. Winch in and the log would just roll up the ramp and drop into the bed....or climb over the other logs in the bed). Worked great even loading by myself.
I kinda miss that trailer. Towed EXTREMELY well, handy for those big CL scores, and a piece of cake to unload . But I sold it a couple years ago along with one of my sawmills, shortly after I moved (where I now have plenty of property to harvest, but only trail access).
MrWhoopee said:I finally got a little bit smarter. Instead of splitting and throwing onto a pile to be stacked, I moved my splitter right next to the stack. Now I stack directly from the splitter, move the splitter as needed. 8v))
Kenster said:Maniac, how much more weight could you handle? Just curious. Wonder how much you're carrying there.
I thought about a pallet fork for the three point on my 8N. The hydraulics can handle up to 1500 pounds but the front wheels come up around 800. I figure I might be able to tote about as much as you're carrying there.
