Check out the scheduled bus tour for the North East Biomass show. Many schools and such have gone with chips over the recent years.
http://nebiomassheat.com/program.php
http://www.biomasscenter.org/resource-library/publications
I would suggest looking through these publications. If I had to pick one, the Wood-Chip Heating Systems: a Guide for Institutional and Commercial Biomass Installations" is a good read.
Some general comments about wood chip applications is they do not scale down well. There are a lot of moving parts in the wood feeding system no matter what the size. The chips are non uniform and but usually in roughly 2" chips. If you are moving tons per hours, the chips flow pretty well but if you are try to move small volumes, the chips clump. Wood chips are generally green and wet when delivered. Let them sit too long and they degrade and sometimes catch fire or mold. If you handle them wet, they tend to be a problem in winter where they are right on edge of freezing, its real easy to get to the point where the chips freeze in clumps if the conditions are right. Many of VT installations very quickly had to switch to "premium" wood chips supplied by one or two suppliers at a premium cost as they couldn't handle the standard grade chips. Chips can be very deceiving, from 20' away they look like uniform chips but get closer and you frequently will find buried under the outer layer sticks and staves which can really foul things up.
Most of the small institutional biomass chip installations were heavily subsidized so they could afford to put the system in. The general preference for small institutional or commercial units are pellet boilers. Pellets may be more expensive but the scale down far better than a biomass plant. I have heard second hand from fairly reliable sources that the amount of day to day attention from the plant staff is a lot higher than they were told when the system was built to the point where the staff has to be increased or diverted to deal with wood handling issues.
Another aspect is depending on the size you could get into the EPA boiler MACT regs which is something you really want to avoid
Hello jebatty. We make an Austrian designed two stage chip boiler in Troy,NY. Company name is Evoworld. The boilers are being built at Troy Boiler Works. They are ASME code and getting labled this Spring. They burn 30% and under chip 2 1/2" and down. I have plenty of information on the system. Product range is from 80MBTU to 1.7MMBTU. How do I get information to you to you?Does anyone use a wood chip boiler, either dry chip or green chip, in a large residential to small/medium commercial application? If so, how has it worked? What's really good? What's not what was expected? etc.? A local school has an interest in taking a look at this because it has a local source of chips, both dry and green. Thanks.
