I'm considering a hydroponic system to heat a home. Before we talk about professionally installed systems - which I will likely use anyway due to safety - I'd like to discuss the opportunities of using a heat exchanger custom molded & attached to the side of a standard woodstove, or fireplace insert, as more of a DIY approach. I know near nothing about floor heating at this point, and I'm trying to learn as much as I can before exploring that option. OTOH I am an avid DIYer.
Actually my first question is a simple one. I do not understand how hydroponic systems aren't constantly boiling and steaming all over the place. Take an example (and please know that I am a complete beginner when it comes to this stuff):
Cheers
- Start with a cold floor. You arrive home & you turn the thermostat up (which starts the boiler or you start a fire in the stove)
- The pump turns on and begins circulating as the water is warming
- Water is warmed and heat transfer to my tile floors begins warming my smiling wife's feet
- Room temperature matches thermostat. When this happens, what does the system do? Does the pump stop circulating hot water? But there's still a fire in the firebox, right? So the water in those pipes is heating very rapidly and is no longer being radiated in the floor, in my puny brain this is going to create steam and will trip the pressure relief.
Cheers
