This is my first post. So let me start off by thanking the many knowledgable members of this online community. I have learned so much already by simply lurking around and reading everything I can. Unfortunately, the more I learn the more I realize I am way over my head with this little project that I am undertaking.
First an accounting of the state of things. I've been contemplating a switch to wood heat for a while now because - as with so many others - my oil bills are astronomical. Additionally I like the idea of being a bit more self sufficient. My buildings and heating systems are as follows:
My original plans were to install a Central Boiler E-Classic 3200 (possibly with unpressurized storage) in the woodshed addition and tie it into my primary system in the house. Leaving my old system basically as is for backup. I was also planning to pull the Hallmark furnace out of the gym and replace it with some kind of fan coil unit so I could keep my existing forced air ducting while using my new furnace. In the garage and wood shop I was planning to use some type of hot water based modine space heaters. The gym, shop and garages would not have backup heat. If the wood furnace goes out - with the current design - those areas would go cold. Which I have no problem with.
Over the course of the winter I've had time to mull all sorts of alternatives over. I've read about the Woodguns, Tarms, Garns, etc. I've considered wood chip systems and even trying to go all solar. In the end i've basically come full circle back to my original plan. Given that the summer is half over and I don't want to run in to the same issue I had last year its time to make some decisions and get this project under way.
SO... I'm hoping for some thoughts and suggestions from the community. I'm not wedded to any system, design, etc at this point. If there were ever a good time for major revisions now would be it. I would like to have a reliable system that will manage my heating needs and hopefully not require tending more than once a day except for maybe the very harshest of days. I don't intend to run the system in the summer for DHW though if I had a storage system maybe I could. Basically, at the moment, I have a relatively clean slate and want to do this right the first time.
Thank you all in advance for reading this long post. Any advice would be much appreciated. If I've left anything out please let me know and I'll attempt to clarify.
Ben
- Coastal Maine on a small hill so very exposed to the elements.
- lots of woodland so limitless, essentially free, wood. Just have to go and get it.
- Primary home:
- ~7500 square feet
- newish construction.
- very well insulated. all blown in closed cell foam
- all radiant heat on all floors in 2" of concrete.
- tall ceilings and lots of windows
- currently heated by Weil Mclain 160k btu oil furnace
- burning about 2200 gallons of #2 fuel annually.
- because of the radiant the house is always kept at exactly the same temp. it barely fluctuates a degree regardless of the outside temp.
- DHW on furnace as well
- Attached "barn" structure
- gym area
- ~2000 square feet
- older construction methods.
- fiberglass insulation
- not kept heated all winter but that will change when the new system is installed.
- currently heated by Hallmark model LB140 forced air furnace. 140k BTU (I think)
- usually burn 500 gallons or so of kero a year but the space is rarely heated as it takes so darn long to come up to temp with the current system.
- very tall ceiling in half of the space (20+')
- Currently I turn the system off completely when not in use. With the new system I anticipate keeping this area at 40 degrees and turning it up when I want to use it so the ability for it to come up to temp quickly is important.
- garage area
- ~2000 square feet.
- currently not heated but will be after install of new heating system.
- in the process of insulating. it will be well insulated with closed cell foam most places.
- will be kept at a constant 45 degrees or so.
- wood shop area
- 1200 square feet
- well insulated with blown in foam in the ceiling and combo of fiberglass and closed cell foam in the walls.
- currently not heated but will be kept at 40 or so and brought up to temp when I want to use it, so it to will need to be able to come up to temp quickly.
- gym area
Ben
![[Hearth.com] Wood boiler questions. Sizing, thoughts, etc. seeking HELP! [Hearth.com] Wood boiler questions. Sizing, thoughts, etc. seeking HELP!](https://www.hearth.com/talk/data/attachments/136/136060-65f770e3ce20dc9c1637ac11e2fd5e4e.jpg?hash=it1oWwvCDQ)
