I just got finished hooking up a riteway wood boiler in my house. It seems to work really well so far. I put an electric blower on the boiler to supply air to the fire to get the water up to temp and when it does the blower turns off. My question is, Is there a way to control the blower so it turns off completely once the water in the boiler cools down (such as when the fire is out)? It is supposed to turn on when the temp of the water goes below 160 to bring the fire back to life and then turn off once the water is up to temp.
I just don't want the blower running all day if the fire goes out completely. Right now the blower is controlled from the aquastat. Im new to this whole thing so any ideas would be helpful. thanks.
Second question is this. I have a second thermostat wired up in conjunction to the thermostat that controls my gas furnace. I was wondering if there was also a way to keep the fan from coming on once the boiler water becomes too cool (such as when the fire is out) to heat the house. I know the gas furnace will kick in eventually, but i keep the boiler thermostat a little higher than the other so if the fire is out and the water is cool the fan will run all day because the boiler thermostat never comes up to the temp it is set at.
Hope i am making sense but any suggestions are appreciated.
thanks, newbe
thanks, newbe
