Finally got her all done this morning, save for the masonry work which will call a mason out in a few weeks to have him finish it off.
Got my first fire in it right now, it's really pumping the heat (and it stinks! as the manual warned me on the first fire). Started off slow. Small amount of wood, but still quite a bit of heat. No condensation issues I can tell, as 1 or 2 others have reported. I used 4" hard duct for the CAK4A chimney air kit, sealing each joint with foil UL tape, and I used 6" hard duct for the outside air kit. CHimney is nice and cool at the base, as well as the CAK. That CAK really has some draw, if I hold a leaf up to the inlet, it sucks it right to the inlet grate.
I only have 2 issues:
1) The paint on the top of the firebox/bottom of baffle board is peeling. Is that normal? Probably, just checking. I just wonder why they would paint it if it's just going to peel on the first fire.
2) Somethings up with my fan. It is definitely wired properly (I checked and double checked), but the fan only comes on 1 speed I think just the rheostat switch they supplied is bad. Any power to the unit is supplied through that rheostat switch, so it seems if the fan is on (either through the snapdisc or the bypass switch), it should adjust speed. But it doesn't. When I take my meter to the switch, it seems to not vary the resistance as I would expect. Granted I don't have a super sensitive expensive meter that can measure very sensitive resistance, but it seems I should see it vary at least .01ohms and I don't.
I'll get that straightened out later. Right now I just want to relax. That thing kicked my butt installing it. Hauling that darn type x drywall up the chase, insulating the chase, hauling those chimney pieces up inside the chase and on top of the roof, rassling that thing in and out of the opening, cutting back my main support headre, fabricating new sub-headers, not the most fun job in the world, but satisfying now that it's complete. Hopefully I'll see a drop in those propane bills this winter!
BTW, thanks for all the help, comments, suggestions, and just being here, this place is a great resource!
