Well, I started a thread last spring about replacing my wood sucking WMC42 unit with a Vermont Castings Sequoia. The object being to save the existing chimney pipe, because new fireplaces seems to want their own propreitary chimney pipe, and I need 30' of it, which is another $700-$1000 depending on model.
The Sequoia unit being the same manufacterer, uses the same S8 Chimney pipe, if I can get it off, which I believe is possible, I will destroy the bottom section, but that's it, I'll buy one section of it.
Anyhow, I tore into my chase today after getting some updated quotes on the sequoia.
What I found, I do not like.
I have a laminated glue beam that is the feature of my living room, loft and master bedroom, and more than that, it's a structural member, it supports the roof of the entire home.
The builder put the header that supports that beam right above the fireplace.
The Sequoia unit requires an framed opening 10" taller than the existing WMC42. I thought I had some fudge factor with the little 5" pedestal he built above the floor I could set the unit on the floor and get another 5", but not 10.
That sucks.
The only thing that might save me is it almost looks like the glue-lam beam is dual supported, the back wall of the chase also has 8 2x4's nailed together, the firestop prevents me from seeing all the way to the top to see if that is truely the case or not, but I would still want to support that front side before I knocked the header out though.
I think that's my next step to check if that back wall support goes to the top to support that glue lam beam up there. I wouldn't want to wreck my home in this process. I don't think my wife would like me very much then.![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
And reference pictures to get an idea of the structure of the home:
That sucks.
