Brian26
https://www.centralmaine.com/2018/10/28/hot-and-cold-on-heat-pumps-in-maine/
Interesting article I will look forward to the study conclusions. I am somewhere in between and my normal choice of fuel is electric or wood with oil as backup if all else fails. I just have one minisplit on my main floor and need to heat my office in the second floor by convection up a stairwell. I find it works well down to about 30 F but unless the sun is out the heat coming up the stairs just doesn't offset the heat loss. Its not a great setup but hard to justify switching my older office cooling only mini split until it dies. I also run the minisplit off of banked "free" solar power so I don't want to burn my surplus up to early in the season.
I do agree that the way to go in cold conditions with a mini split is set it and forget it. Its definitely takes several hours to warm up a cold house when I am out of town on business for few days. My normal approach is heat up the wood boiler storage before I head out and set back the thermostats to 60 F and then set the minisplit to 64F. That will carry the house for several days unless its really cold (below zero). When I get home I crank up the boiler to reheat the house as the minisplit may take 12 plus hours.
The other issue is if its damp or snowing in cold conditions the coils frost up quicker and that means more defrost cycles which are noisy. Mine is situated on the downwind side of the house well off the ground with roof over it to deflect snow but it its blowing snow it can get frosted up.
I did a recent posting that a family friend that does vented kerosene heaters is getting a lot of calls from folks with minisplits to get their old Monitors repaired or new ones installed for cold weather heating. A minisplit just doesn't put out very warm air in cold conditions and along with the fan running full bore it can get drafty. A Monitor puts out a lot warmer air and can put out more of it when needed.
Not sure if you saw this article with the linked evaulation. Its a good read about mini splits in Mass and Rhode Island.
https://blog.greenenergyconsumers.org/blog/we-need-a-plan-for-ductless-mini-split-heat-pumps
Given that our organization works in both Massachusetts and Rhode Island, we were anxious to read a (broken link removed) conducted for utilities in those states by the Cadmus Group. The study cost several hundred thousand dollars, took over two years, and analyzed data from over 150 homes. Here is a summary of some of the findings highlighted in the report
Interesting section from the study.
The figure also shows a temperature balance point about 32°F for an oil‐fired system in 2016 and 12°F
in 2015. Both winters indicate a propane balance point of ‐15°F, meaning a DMSHP would always be less
expensive than the propane option.
Figure ES‐7 shows the same analysis, but addresses units listed as cold climate. These units operate
somewhat more efficiently, and the economic balance points shift to colder temperatures, where gas
balance points were at or above 58°F for both winters. Oil‐fired systems’ balance points were 26°F for
2016 and 8°F for 2015. These values do not account for zonal savings. For example, if a homeowner
could use a DMSHP to heat 30% less of their home, that temperature balance point would drop by 20°F
or more.
