Ashful
Sorry to be a pain..but I'm right.....Just buy winter bar oil. Your dealer doesn't have a clue.
Umm... for the record, I was agreeing with you, and never discussed this with my dealer. I think you quoted the wrong guy.
find-a-dealer that knows. Mine gives me a deal by the case 2 gals for summer and 2 gals for winter for $38. Winter weight makes a big difference when it get gets below freezing up here. if you use summer weight in the winter you will go through 75% less oil and 175% more gas, chain, & bar.
Below 30you can have problems with summer weight oil. To get around that, I leave my saw and bar oil in the mud room at night if I am going to cut in below freezing weather the next day. Once the saw gets warm the oil tank at the front of the saw near the muffler will keep the oil warm enough to flow well, and having room temp oil in the jug when you go out will usually stay warm enough for the day of cutting.
So how long does it take for the saw to get to operating temp ? I would think not long
. Material in the bar goove makes for thrown chains, which happened in this instance.
, set your saw down for a while, and then go back to cutting? The entire system can cool quickly.
I did think of it, cuz it just makes sense you need something different, so this thread is answering what I would have asked in my own .The entire system can cool quickly.
Set one of them down in the snow and it'll cool off almost instantly.Not only that my husky 61 has a plug to remove to increase temps to carb, so I guess, I should pull the plug also, ??
So your damned if U do, damned it U don't, It's all arbitrary ???Most Stihl saws also have Winter/Summer flip tabs around the spark plug and air filter. That allows more warm air to get into the intake and help prevent carbing. Problem with winter mode is that more sawdust also gets into the air filter area.
Cleaning the filter a little more often is better than a saw you can't run 'cause it bogs out every time you hit the throttle. The first time you experience Carb Icing you'll get mad, and then be all "WTF?!". Then it hits you. "Ohhhhhh...."So your damned if U do, damned it U don't, It's all arbitrary ???
Seems to me, if U want your saws running peak, U need the type of tach I have seen in vids,but don't know aboutI noticed tonight that my 034 was a tad rich up high, last time I tuned, it was in the 50's-60's. Prob in the high 20's tonight. I noticed I had to lean on 'er a bit to get it to quit four-stroking. I'll check the air filter and sharpen the chain I guess.
I only re-tune in the field if something doesn't sound right to me. I'll check each saw from time to time with a tach to make sure I'm not exceeding the "redline" at WOT no-load. I do that just about every time they get a thorough cleaning.
Stihl EDT 7 is a great one, not too awful on the wallet either. (I don't remember the specifics but I remember being pleasantly surprised.) It really depends on how much you trust your ears. Me? I got da' tach.Seems to me, if U want your saws running peak, U need the type of tach I have seen in vids,but don't know about
For you guys adding in some kero to make your own winter blend, how much do you generally add to a 1/2 gallon of standard bar/chain oil? A cup? A pint?
MasterMech, do you set your H screw by the tach? Make sure it's four-stroking at some percentage of max rated RPM? Or just tune by ear, then verify max RPM on the tach?
So !! what about tuning for the temp![]()
Your name should be Stihl Overkhill lol..I have a Tech Tac TT 20k. Wireless (but has a wired option), you only need to get the tach a few inches from the saw engine and it reads out the RMP digitally. They are about $90 with shipping (click in this link to see it/order one: Edge and Engine). I retune my saws when I change bar lengths or do any work on them, or if I change oil or gas type. Fast-Tach is another similar tach made by the same company. Tiny Tach is another tach that is similar.
And my usual disclaimer: No, I do not work for Edge and Engine, or Stihl or Husqvarna, or any oil company, or DTI Industries or any tachometer company, nor do I get any financial payments, kickbacks or discounts from any of them for my posting here or anywhere else. Edge and Engine is the cheapest place to buy a DTI Tech Tach 20k that I have found, and that is where I got mine several years ago.
