Aware there is a wealth of knowledge and expertise here. Many thanks to all. For 33 yrs I've been burning my VC Winter Warm...Recently fried the cat, the back wall is warped and cannot operate the damper controls...Okay stupid me over fired...Hearth shops claims not irrational to pour $$$ into this system..
To complicate matters 4 yrs ago my external stack was past repointing multiple sites so the Master Chimney repair removed clay tiles , installed a twin wall S/S 8"liner, fabricated a stainless 8" round to oval connector to hook up to the WW. Hung a lathe and stucco'd the chimney and sealed with 15yr Dura Lock waterproofing...Warranty=15yr for the overlay..BTW chimney repair cracked open the external wall to install the fabricated transition.
New fireplace inserts these days have 6" collars....I've read enough of BeGreen's posts to know an increaser is not the way to go...The chimney height is 20-25ft...Hearth shop advises that they have used an increasers in the field with no reported issues....LOL...I am afraid of drafting problems...My chimney faces west....windy in winter here on Long Island.
The fireplace is basically a zero clearance, no raised hearth, sits about 6 inches above 16" slate tiles across the field stone fascia...No Buck dealers in my neck of the woods and Blaze King has maybe 1 or 2 at best locally....Been eyeing the Osburn 3500-I (love n/s loading ability) and the Matrix-I as new candidates...I will need a riser for the flush unit and worried the 3500 will stick out too far....Aware I can use an apron b/c this is going to be expensive.
A transition may be my only option since b/c a top may not be possible on the liner...Originally when the WW was installed hearth shop advised they could not run a liner all the way up the chimney...My husband was in charge then and I cannot recall why....Not sure if a 6" liner can go down the throat of the existing setup...I wish I could repair the WW but in later years wasn't;t running as hot(seal or weld problem?) Sorry for the long post...I am having a different chimney company coming to inspect but the WW is still installed...Removing over 600lbs of solid cast iron is scaring the hell out of me.
Thanking you in advance...
