Winter time wood transport
Still using the Mexican dump truck (wheelbarrow). I usually bring in a cord and a half at a clip. I have a root cellar where I store this which is ten feet from the stove, just out the back door. We get the snow here, nothing like VT. Last year I keep a route shoveled to the wood pile, about 25 yards. The down fall was late winter early spring when things begin to thaw, MUD! So I was tring to time it with the cold mornings so the ground is still firm.
KC
I access my 4 cord from my kitchen door, goes into a enclosed patio..yeah, I wear my slippers :)
Skier76 said:
moosetrek said:
Skier76, What's the price on that deal with the brackets? I have an idea for a homemade one but need to know if it's worth the $ for the materials... If so, I'll post separately if it works...
About $20 for each set of brackets. One set of 4 brackets allows you to make one wood holder. Plus the cost of the 2x4's, but that's really not that bad.
Menard's has the full set for $10 if you have one near.
Ja, and we have pics to prove it.
  • [Hearth.com] Winter time wood transport
remember the plastic sleds when we were a kid?.... works like a charm
Glad I got my stack (which is as deep as the garage 30') next to the house.
How about one of these?
I have a big pile of wood right next to the boiler shed for when the snow sets in and I use one of those 4 wheeled pull garden cart other wise I use the 4 wheeler and a bigger cart to bring wood to the shed
I'm in the process of copying my father-in-laws design of a wood sled. Its 2- 3/4" ply wood sides appx 2' x4', with a 2' radius on on end, a 2' x 2' wooden flat back, then heavy gage sheet metal on the bottom. (steel roofing, galv ducting, ect.). This is screwed on with Sheet Metal Screws. A heavy duty eye bolt on the front for pulling w/ the tractor. There will also be 2" holes in the sides to put a rope threw to pull by hand. I am copying it because I'm now heating with wood and Ive helped him haul the wood for his house in this simple sled for years and it work great. I also works great to put your logging tools in and hook up to the back of the 3 pt hitch with the work bar on. The eye bolt goes into the top link and the rest sits on the work bar. Such a super simple design but it works great. Ill try to snap a photo and post if I can. Last year my 9 yr old was pulling the thing thru the snow with relative ease. If you really load it up you can get quite a bit of wood in it and it slides easily in the snow.
crazy_dan said:
I use a garden cart rated at 1,000lbs and I am legally obligated to state that it works great.
one of these and this is where the wife bought it http://www.tractorsupply.com/lawn-g...gorilla-carts-heavy-duty-utility-cart-3599202
I have a similar cart in red, I think it's the same otherwise... works well, but I found it has some limitations...
1. If putting a lot of weight in it (like a big round), you need to reinforce the bed or it will flex and bend. The construction is very light, the only way you'd get 1,000lbs on it w/o reinforcement is if it was something very distributed like fertilizer sacks...
2. I did manage to break the front steering suspension on it going over some rough ground. (However after a fair bit of phoning around I was able to get a replacement at no cost...)
3. It tows forwards nicely when hooked to the lawn tractor, but can't readily be backed up - Essentially I found that you have to unhook, push the trailer into location by hand, then back the tractor up and reconnect.
Still, I'm glad I bought it, and I do use it a lot.
Gooserider
Like to see pics of this!!
