As far as dogs go. They just give you more leverage to push the saw and load up the chain. I don’t see how that’s helpful for a medium saw in big wood. Increasing load I. The saw increase chances you burn it up.
If cutting small stuff, where more time is spent moving the saw from one cut to the next than actually cutting wood, sure. But once you're into anything much over 1 foot in diameter, the larger saw will always be very noticeably faster than the smaller saw. This lets me get thru any pile of medium or large diameter logs faster and with far less fatigue with the 064, than I ever could with the 036. You might have some argument if the job meant hauling the saw some long distance into the wood by hand, but for any other scenario, the larger and faster saw always wins.The lightest saw I hat gets the job in a reasonable amp of time is the safest IMO. No way I’d be lugging my 25+ pound 660 clone to buck that pile.
Exactly what I am doing.Not really. Start from the top and roll off the chunks as you cut. I really don’t see why this is tricky. It looks normal to me. Am I missing something?
Good recommendation. I run skip tooth on my 36" bar, when I mount it on the 064. Good way to stretch the available power of a saw, when you need to run a long bar.28" and skip tooth for the win
Faster to sharpen too.Good recommendation. I run skip tooth on my 36" bar, when I mount it on the 064. Good way to stretch the available power of a saw, when you need to run a long bar.
Yeah. Sharpening 36" loops of full-comp chain is an exercise in patience. Thankfully, I almost never have a real need to use that bar. Occasionally I'll be dropping a tree where it's not real safe to work from both sides, so I'll mount up the 36" bar for those, if it allows me to take the tree while working from just one side. But otherwise I keep a 28" sprocket nose bar on that saw, pretty much all the time.Faster to sharpen too.
Wow, amazing, you are really sharp/on top of things/observant/experienced.I am more of a Husky man. I fully respect Stihl makes good saws once you get above (applies to Husky too) the entry level homeowner products.
Having said that, a good name saw with 65cc displacement and a 25" bar has you in the game. I do think you need some gear you don't have, but I would not be in a hurry to get an even bigger saw. I think you need at least two medium length handles, and some wedges.
For the kerfing wedges, you could use felling wedges if you have them already. Plastic, won't hurt the chain if you have some kickback. Cheap as chips wherever you can buy a forestry helmet and some kevlar chaps. Get three or four.
There is some regional variation in the common names of logging tools.
In my my mind, you don't need a cant hook. When you have some of the bark sawn off a log at the mill you have a cant on the ways and you don't want to mess up the sawn surfaces. So a cant hook has a square end on the end of the handle, and a swinging jaw on one side to rotate the cant on the ways to slice off some more bark on your way to making lumber. You do not need a cant hook.
Another similar tool is called by many a Peavy. It has a pointy end on the stick (different from a cant hook) and a swinging jaw (same as a cant hook) and you probably do need a Peavy. Mr. Peavy has been dead a really long time, but his tool of choice is real handy for breaking up log jams on flowing rivers during the spring melt- and wrestling logs around on the ground.
Another to consider is called variously a timber jack or a log jack. This one has all kinds of points on the end of the stick made up by people who use more hair products than us, and a swinging jaw like a Peavey or a cant hook, but 180 degrees around the stick from the swinging jaw is a fixed leg with a foot of some kind on it.
I personally have no use for timberjacks or log jacks, but they are useful in some situations. I mostly have small logs growing up here. You are knee deep in big logs. Timberjacks can be useful for medium sized logs.
So here is what I see.
You got some really nice logs, that could have been desirable to a sawmill to make construction lumber from. Your Sonoma County location would put your local Doug Fir into the DF-Western Larch design values, highly desirable lumber for the construction industry, but someone gave it to you for free. Either the site foreman lost an opportunity to make a buck for his boss, or the quantity was too small to interest a sawmill, or there is a known issue with these logs an onsite sawyer did see that I can't see in your pics.
I ass/u/me there is an issue with these trees that kept them from becoming 2x4s and you should expect your bar to get pinched over and over. Ergo, kerfing wedges. Among felling wedges (narrow angle, very acute), there are some that can be stacked and latched to make a fatter, less acute kerfing wedge. Get those ones, stack them two at a time to make kerfing wedges, and use them in every cut every time.
I personally would go after these logs on the ground with a Peavey. I would chalk them up every 16 inches, cut partway through, rotate them with a Peavey and then finish the cut. On soft ground you might slice 1/3 through, rotate 120 degrees, cut some more, rotate again and then finish your cuts. With the saw you already got.
I personally buy all my wood handled tools in person. The main trouble seems to be the folks writing internet reviews didn't grow up on farms and cannot tell a post hole digger from a grain sickle. For logging tools you want a tool made in USA, Canada, Scandinavia or the Baltic states. Germany would be fine, though I have never seen one. Just drive on down to Menards or Tractor Supply or similar and take all the Peavey's (my suggestion) off the rack and set them respectfully on the floor. If they are well made and you treat them with respect your grandson may have to touch up the point of your Peavey. All the ones with visible knots in the handle bigger than 1/10 of one inch go back in the rack. If there are none left on the floor, go to another store and look there. Once you have a couple Peaveys left on the floor with no knots >1/10 of one inch you are going to be happiest with Ash and if you can get it you want the (straight) end grain in the handle parallel to the swing of the moving jaw. From what I have seen of rough sawn 8/4 and 12/4 ash lumber lately we got a bunch of crackheads and meth addicts somewhere in the supply chain, so good luck with this, but keep looking; even a stopped clock tells the correct time twice daily. After straight grain parallel to the swing of the jaw, I would be second happiest with straight end grain perpendicular to the swing of the jaw.
But the grain needs to run true all the way through the handle. When you look at the eyeball end of the handle, that visible growth ring in the center needs to run all the way to the point of the tool. If you see "cathedral grain" (a fashion statement), put that one back on the shelf. Grain runout (visible cathedral grain) is no bueno for working tools. This attention to detail is sadly lacking in my experience with tool manufacturers lately and has been really bad since the early 1980s. Some mfrs gave up on ideal grained wood handles long before snorting coke in a BMW while listening to Duran Duran or Kenny Loggins was a thing.
The thing about Ash and Hickory handles is when you increase the force you are applying gently and smoothly they are unbreakable by mortal man. I can break 300-500 pounds of ice off a glacier with a shovel no problem, when I treat the tool with respect. If I pounce on the shovel and apply infinite force instantly, I can break ash. When you are trying to roll one of your big logs, take the slack out of your Peavey handle first, then roll the log if it isn't moving already. Just focus on loading up the handle gently (while applying beastly force) until the log is moving. Ash and hickory can turn any of the logs pictured no problem if you got no knots >1/10 and whatever for straight grain.
When you are done with this log pile you will be accomplished at sharpening. Your biggest problem is going to be keeping your chain out of the dirt. My counsel is to start with one sharp chain, get the Stihl file guide, and sharpen the one chain on the saw over and over until you either get to the tell tale marks or are finished with that log pile. Once you know what you are doing, and you will soon, it is faster to sharpen on the saw than it is to screw around changing chains. Today it might be faster for you to change out chains and sharpen after hours, but at the end of this log pile you will not regret learning to sharpen the chain on the saw. Touch up your chain every time you touch down on dirt and every second fuel tank. You will have a useful skill for life.
Keep PLENTY of bar oil on your chain file, and tap it regularly on something that is allowed to have dents in it, like the inside of your tailgate.
Besides sharp, consider raker depth. Likely Stihl (Husky does) there will be two raker depth settings on your factory file guide. One for hardwood and one for softwood. As you sharpen each tooth shorter and closer to the wear mark your rakers will be getting taller and taller. Eventually your saw will bog down on Doug Fir in summertime with sharp teeth because your rakers are too tall, your depth of cut is too much. At this juncture you will need to file your rakers down a little bit to reduce your depth of cut per tooth. Doug Fir (Queen of the West) and Southern Yellow Pine, SYP (King of the South) are both 'tweeners' between hardwoods like oak and softwoods like eastern white pine. I cannot possibly tell you what your raker height should be. When the saw is bogging on sharp teeth, your rakers are too tall. File them down 'some' and try again.
At -30dF I file my rakers to "husky hardwood" height for spruce. What raker height you can get away with in summertime in California on DF-WL with a respectable Stihl is very much outside my wheelhouse.
Good luck, best wishes, a full suite of forestry PPE is about 10% the price of one ER visit for a chainsaw injury. My first forestry helmet took a high speed hit from a chunk of North Carolina oak about 3x3x3 inches in front of my left eye and remained in service for several years afterwards. PPE is cheap, outpatient follow up after a chainsaw injury is not cheap.
Yeah. I think he just misspoke. I intentionally take my rakers down about .01" (~30%) lower than recommended, for this reason. Another reason why I'm probably always harping on smaller bars on bigger motors.Am I missing something? @Poindexter says long rakers result in too much cut and bogging/overload the saw. I thought overly long rakers would hold the cutting teeth away from the wood resulting in too shallow of a cut. If I grind the rakers too much then the cutting teeth get a big mouth full.
DefinitelyAnother reason why I'm probably always harping on smaller bars on bigger motors.
