i understand that they are expensive and underpowered. This guy is trying to appease the wife though.
Dyson fan is crazy, but thx for the idea. I still don't have an logical reason why the duct work in my attic would work for cooling but not for heating. Any takers?
1) Your stove will not make all rooms the same temperature. Get used to it, welcome to wood heat. The stove room will be warmer than the far bedrooms. I experience a 10 degree difference and really like it this way.
I just started using one of the little Honeywell fans on the floor of the coldest room, and the difference was immediate. That particular brand is pretty quiet, and my wife is very sensitive to anything noisy, so it passes that test here.
-JE
Any way you can get under the house to install a cold air return to the stove room?
I really need to do that at my place. If I could find where to get under the house
Are those oil filled units the most energy efficient? I have one cold room that I'm never going to get it as warm as the rest of the house, was thinking of putting something in there when the room is used.My common area is separated by the bedrooms by a hallway. I have a small fan near the end of the hallway pointed toward the stove room. I also have 2 oil filled electric units in the bedrooms on a timer. 1 hour before bedtime. You could also set the timer for every other 1/2 hour within a certain time period.
Full basement? I'd have a return from every far room Yea, I'd find an inline vent for a bathroom, or maybe a larger squirrel-cage type fan.Hmmm. I have a full basement so it would be very easy. Would you put an inline fan of some sort?
