Mike PA said:Actually I already stated a positive in my previous post. I nearly lost my foot because the tree was able to slide backwards off the trunk when the hinge broke prematurely while I was pounding a steel wedge in the straight (not angled) back cut.
Had I angled the back cut (even slightly) the tree base could not have slid backwards ,up and over, the angle when the hinge broke.
Obviously the hinge was cut to thin, but that's not the point, the point is that a (slightly) angled back cut has a "positive" safety feature when other things go wrong. And as long as one remembers that there is a "negative" by cutting at too much of an angle I believe a slight angle is a good thing, and I will continue to put a slight angle in my back cuts.
The point here really is that you made the hinge too thin and broke it off by pounding in the wedge. Also, the wedge may have been too thick to be effective, whihc may have also led to the failure. An angled back cut may have caused the tree to land entirely different, but with no better or more predictable results. The problem wasn't the angle, it was the hinge.
This brings up another issue on why a horizontal cut is best - all of the force applied with a wedge should goe to lifting the tree. With an angled cut, a portion of the force goes more in the horizontal, increasing the chances of breaking the hinge prematurely. Conversely, an angled cut with a wedge applies force to a narrow area on the stump and applies force away from the stump, possibly casuing the stump to split or fail below the wedge and loosing control of the tree. As someone else stated, it is easier to make a mistake with an angled backcut and getting below the felling notch.[/quote]
In this particular case the "problem" was that the branches of the tree I was cutting were intertwined with the branches of the trees branches surrounding it, thus the tree was reluctant to fall. yes I cut out a little more of the hinge, and ,,,, I also used a bigger wedge and,,, hit it a LOT harder then I usually need to That is what led to the hinge breaking. An angled back cut definitely would have stopped the tree from sliding off my side of the stump and nearly impaling my foot the way it did. I would much rather have had the tree fall over backward towards me, or side ways, at least when it does that you have time to react. When the hinge breaks like it did there is absolutely no time to react. The tree will not, can not, slide up hill, so there is no way it could have done what it did.
A couple more points to chew on; Not all trees are built the same, some are much more brittle than others and some trees are rotten in the middle, both can add uncertainty as to the strength and integrity of the hinge, so assuming all you gota do is cut the hinge correctly is not being very prepared for the unexpected. The other thing is, there is no such thing as a perfectly horizontal cut. Next time you go cut a tree down take your pocket level with you and check your "horizontal" back cut. Chances of it being perfectly level are next to nil. Will that effect your cut?, No. Why not? , because a slight amount of angle doesn't cause all the problems that have been mentioned. That being the case, then why not, since there is going to be some kind of slight angle anyway, why not make sure the angle is a slight down angle that will protect you in case of a unexpected hinge break.
, please don't put words in my mouth, that's not what I'm saying.
