Yeh Roo, I'm looking to monitor max temp but I have to confess alot of it is just because of listening to everybody else kickin' back and forth about their temps and feeling left out of the party. ![Stick Out Tongue :p :p](/talk/styles/default/xenforo/smileys/raspberry.gif)
I have a similar set up. I just use an infrared thermometer. I have used it less and less as I've gotten more comfortable with the stove. I really only use it now when I come home and my wife has added wood to the fire and not really checked on it. She had it up to 800 F last time!PacificGuyInCNY said:I know about thermometer placement on a stove, but what would you recommend for an insert? I know about the center-vs-side argument - that center will be sensitive to the secondary burn - but there still seem to be a number of different opinions out there. My Summit (and I think most other inserts) don't leave you with a whole lot of options (see below). Is it possible to get a remote flue sensor to read pipe temperature like on a stove?
BrotherBart said:It has been useful starting out with a newer technology stove but before long it will be back to eyeballing it.
How much of using it has come from all of the talk here about temps and how much was parinoia from Ole Brownie running away on me I don't know.
PacificGuyInCNY said:Bart, if that baby ever does go full runaway be sure to take a pic on the way out the door...
PacificGuyInCNY said:Bart, that's amazing. Just out of curiosity what kinda stove was the "Old Big Hoss"?
BrotherBart said:PacificGuyInCNY said:Bart, that's amazing. Just out of curiosity what kinda stove was the "Old Big Hoss"?
Sierra T-4600 Royale insert. 4.2 cubic foot firebox. 1/4" steel body wrap and 3/8" plate top. There was as much stove behind that surround as in front of it.
ozarkjeep said:is that lever on top a catalytic bypass damper?
if so that stove appears to designed similarly to my own.
a runaway would be scary with a firebox that large if it was full!
Roospike said:*************** ;-) *****************
Roospike said:So would you agree that with experence ( 4 months or 40 years ) the "need" for a stove thermometer is not needed and is not a priority to running a wood stove.
Roospike said:Robbie said:Who needs them ? I can tell by looking at my fire what my temp is...........................![]()
The answer to the original question I think would cost, liability, etc.
OK.........I'm stretching the truth a bit, I use one of these below, actually I have 2 now, both on my stove front, work great, could not operate without them.
http://www.condar.com/meters.html
Robbie
OK , Anyone. Here is a question about stove top thermometers .............
At what tempture does the stove top thermometer need to be when its 32° out side and its 9:00 pm ? 400-500
At what tempture does the stove top thermometer need to be when its 40° out side and its 9:00 am ? 400
At what tempture does the stove top thermometer need to be when its 16° out side and its 11:00 am ? 500-600
At what tempture does the stove top thermometer need to be when its 50° out side and its 10:00 pm ? don't run stove, maybe a quick flash fire to take chill off.
Do you know the exact #'s the stove top thermometer should be reading ? or are we just running the stove at 550° all the time ?
MrGriz said:As a newbie to burning in an insert, I want to be sure that I am burning correctly. The manual that came with my insert does virtually nothing to educate on the proper way to burn and control things. I may be over analyzing and putting too much thought into things, but I would like to get it right. Not only do I want to minimize the creation of creosote in the liner, maximize the burn time of my wood, create as little emission as possible, I also don't want to damage the insert in the process.
At this time I am thinking that an accurate thermometer and a guideline of optimum brun temps would be helpful. That way, I could observe what's going on inside the insert at different temps and eventually pay no attention to the thermometer. I guess at this stage in my learning curve it would be a good backup or reference point.
As good an analogy I can come up with at this time is that of a speedometer in a car. When you first learn to drive, you watch it pretty closely. At some point, you stop relying on it so much and only give it a second look when you go flying past a cop taking radar.
Five minutes later the stove top was at twelve hundred and eighty three degrees and glowing cherry red. 3/8 steel plate.
hardwood715 said:Five minutes later the stove top was at twelve hundred and eighty three degrees and glowing cherry red. 3/8 steel plate.
BB outta curiosity, how hot did the fireplace bricks get? And I would think its alot better to happen on an insert versus a standalone, I mean the brick can handle the heat versus say a couch and chair close by, right? 1283 damn- what guage were you using? the condor woulda been pegged as it rolled around the room!
Warren said:MrGriz said:As a newbie to burning in an insert, I want to be sure that I am burning correctly. The manual that came with my insert does virtually nothing to educate on the proper way to burn and control things. I may be over analyzing and putting too much thought into things, but I would like to get it right. Not only do I want to minimize the creation of creosote in the liner, maximize the burn time of my wood, create as little emission as possible, I also don't want to damage the insert in the process.
You've seen my posts on Osburn temps haven't you?
